Chips and Scratches
485
Hunter 44 Mystic, Ct
I want to repair a few minor chips and shallow scratches in the vertical sections of my hull using one of the several gel coat repair products in a tube. Anyone have any experience using any of these products for a vertcal repair? Obvious question is how do you stop the product fom flowing out?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Most of them are viscous enough not to flow out of the repair area.
Question collorary: Has anyone ever had a very good (Not excellent) -defined as level, same color, texture and gloss but detectable with a close look - result with these products? If so how was it done? -
Nov 8, 2009
537
Hunter 386LE San Fancisco
Suggest a one-step white gelcoat repair ($12/tube) to fill in topside, bow and rail chips and scratches. Squeeze it on and scrape if off so it is flush with the surface. After it dries wet sand with 400 grit then 100 grit sandpaper then wax and buff. I just did this on my sail boat to refinish 23 years of chips and scratches. I did the same last year on my ski boat to remove a large scratch in 2 colored sections using a small wood block. Key is start with 400 grit wet sanding paper then progress to 1200 girt wet sanding paper and eventually to polishing compound then wax and buff it out. Good luck.
Oct 22, 2008
3,502
Believe Stephen means 400 grit and 1000 grit...
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Sometimes applying a piece of tape over the repair - after you've applied the goop, but before it runs out - will keep it in place while it cures AND make sanding much easier.
Jun 21, 2007
2,118
One thing about color matching that I read about and also observed when filling a scratch on my hull side (orginal factory gelcoat) is that the fill color should be matched before any sanding (or anything else) is done to the area. But after the sanding/polishing/waxing, you may find that the new gelcoat and the surrounding original hull no longer match. No worries however. This happens because the original hull's surface which is exposed to the sun/elements is likely to have a different shading than the unexposed gelcoat which you'll make newly exposed by the sanding etc. In my case, the original surface was very white. But after sanding and polishing, it became a cream white and the new white repair material was evident in constrast. In a few months, the newly exposed surface weathers back and the repair color (which you got right to begin with?!) will again match. Mine ended up very close ... I have to look hard to notice the repair.
