Even in your drawing where you illustrate the 1:1, if the line is pulling at a 45 to the line of action of the boom than the true purchase is cut in half. I see where Kloudie is coming from. I also see what you are saying.
Scott's setup is not like the Catalina 30 rigging diagram... he is missing the extra block in the middle of the gang. So... Sailingdog is correct... it is only 5:1.The way the boat is rigged in the photo is a 5:1 mechanical advantage, not 6:1.
I disagree. Inserting another block at the gooseneck will not change anything, purchase wise. What it will change is the allocation of effort, balancing it between the two mast blocks,(90+90 degrees). As it is now the front bail's block handles about 30 deg, while the mast base handles around 150. If the gooseneck block is added, the forward mast block reverts to only being part of purchase effort #4. Its strain will be significantly reduced and more in line with the direction of the bail, i.e. pointing in the direction of the traveller.You could change it to 5:1 by putting a block on the goseneck before leading it down to the deck..
Sorry, I can't get the picture from the manual posted... maybe someone can help if there is any interest left in this thread. http://www.catalina30.com/TechLib/PartsManual/Rigging.pdf see page 8.
Even if you go by the catalina diagram, that bail is facing the wrong way. If you notice in the drawing it is hanging unnaturally. That was in the days of hand drafting, mistakes that were small often stayed put.
Hi again,That's why I was suggesting the triple block with becket for the mainsheet traveler car, so that the lines would pull in alignment with the bails, reduce the risk of damaging the boom, and keep clear of the boom vang.![]()
towman-I was intending to put an arch across the back, that would get used for the dinghy, and maybe hooking a bimini to it. If I put the arch forward enough to put the traveller on it, then I can't use it for the dinghy and would be effectively useless. If I put an arch in the front, I get to make a dodger(actually removable hard windows) to cover the companionway. I think that would add the most comfort. I kinda like hauling the inflatable up onto the deck with a halyard and keeping it there.
Also I can say with certainty that a rigid vang is in Event Horizon's future.
Joe-that is a good choice for a triple block for this problem.
I thought the main sheet HAD to go from somewhere on the boom to the mast or goose neck to allow it to go along the traveller without releasing the mainsheet tension? Did you do that yourself or is the factory?Scott,
Here is how my mainsheet is lead back to the cockpit winch. The boom is set up with three blocks and a fiddle block on the traveller like yours. Hope it helps for an idea.
