The mast is stepped on a plate. Disconnect and label all the wires. Clean the plate and the bottom of the mast before restepping, use Lanacote. Install a coin on the mast plate for good luck. Consider replacing all the lamp cord Catalina used to use for mast wiring.
I have unstepped the mast on my Catalina 30 # 573.I need to step my mast to replace OEM wooden spreaders. Does the C30 mast step like the C27? If not any words of wisdom/experience?
