Cambridge to Cape May
195
Hunter 310 Bivalve, Md
I have a friend planning a trip North from Cambridge Md to the Deleware canal and down to Cape May on Wednesday. He thinks it will only be 20 some hours, I'm guessing 35+ with no stops:eek:. Wind is to be from the south when he leaves and has invited me to go along. The boat is a Catalina 36 with radar and autohelm and I've sail it before and its comfortable. I need the experience so I think I'm going. Any advice besides life insurance?
Sep 29, 2008
1,978
Catalina 310 #185 Quantico
Tides
Have not done it, but the guides I have read and people I have talked to say to watch the tides through the canal and in the Delaware. They also say it can get rough in the Delaware Bay.
xsiddr
Jun 14, 2009
34
BENETEAU 361 Worton Creek, MD
no problem
My wife and I have made that run many times, first in our Catalina 30 and then in our Beneteau361. Just time the tides and have fun. The lower part of the bay ie. 2-3 hours above Cape May can be choppy but it can also be smooth and dead calm.
just be prepared to see the Salem Nuclear Power plant for hours on end. When you go thru the Cape May canal, pay close attention that you're aiming for the right marker once you clear the last bridge. Anchor in front of the CG base. The CG boats will be to your right when you have past them and there is 5-6 depth near the sea wall. Try and stay closer to the channel as the tidal change could have you bumping. Good holding and you can dinghy over to the Lobster House for dinner. Have a great time.
Bob
s/v Kaylic B361
Ross
Jun 15, 2004
14,693
Re: Tides
Has your friend gotten his dividers out and checked the distance? St Michaels to Havre de Grace is 18 hours. Check the tides and the C&D traffic. Pack food for a week.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Check the mast height, there is a 55' bridge in the Cape May Canal. The area experiences a 6 to 7 feet tide and you may not want to get there at high tide to go under the bridge. Going around will add a couple of hours to the trip. Delaware Bay has a strong tidal flow so you would want to time your departure from the C&D canal to make utmost use of the outgoing flow. Delaware Bay is also shallow and when wind opposes current a nasty uncomfortable chop develops. Would advice against trying to navigate Delaware Bay after dark. many shallow areas require that you stay in the canal and there is a lot of fast moving commercial traffic. Going down there are not many convinient anchorages so it is best to start early and get to Cape may before sundown. Check the tides and currents for the day of the trip. There are appropiate days and not so appropiate days. If it were me i would break up the trip into two days; if you are traveling during the week there are free transient slips on Chesapeake City on the C&D canal. With proper planning the trip can be quite pleasent.
Ross
Jun 15, 2004
14,693
With a quick check with dividers I make the trip about 160 miles.
Jun 3, 2004
418
Island Packet Island Packet 29 West River, MD
24 Hours
Marc,
I've made the trip from Oxford to Cape May in an Island Packet 27 under auxiliary power the whole way. It took 24 hours without stopping.
Good luck.
Ross
Jun 15, 2004
14,693
Marc,
Good luck.
WHY? that's not much fun.
Sep 30, 2008
195
Funny Ross. I enjoy all your posts. I'd like to meet you some day and talk sailing. It would be a one sided conversation as I'm a rookie, but I like doing things for myself and learning.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I've done the Annapolis to Cape May section recently as part of a delivery. It really isn't that bad a trip. Plan you passage to take advantage of the tidal currents, and use the radar, especially at night, since the big ships can creep up on you unexpectedly.
Some advice:
Don't drink alcohol for a day or so before the trip. Alcohol adversely affects your balance, your night vision and your judgement.
Stay well hydrated during your watches.
Bring the following:
A good flashlight, preferably with both a red and white beam or a red filter
A good wide-mouth vacuum insulated flask.
A good PFD with integrated harness
Good sunglasses
A hat
Beneteau 323 Annapolis MD
You'd want to hit the C&D when it is the low tide on the Bay side to catch the current through the canal. You want to hit the Delaware when it is high tide at Reedie Point, the east end of the C&D. A quick check shows the 26-29th tide at 0719,0826,0927,1023. You could hit the Delaware an hour or so before that since the north-flowing tide should not be so bad. Problem is, if you say the wind will be from the south, you'll have choppy condition going down the bay if you have an outgoing tide. I have a Chesapeake bay chart on the wall right next to me, with major markers noted and mileage between each. If you use the Cape may channel, I show about 48 miles from Reedie Point to the entrance of the channel.
The bay crusing guide show Cambridge to Chesapeake City as 81 miles., plus about 50, plus 13 in the canal.
Ariel
Feb 1, 2006
279
Pearson 36-2 Houston, TX / Rock Hall, MD
Marc,
Check the tides in Delaware Bay, carefully watch the weather forecasts and check the bridge clearence of the bridges over the Cape May canal (we once scraped them at high spring tide). Then enjoy the sail. We have made this trip numerious times in our Pearson 36-2, although we always stop in Chesapeake City and time the tides in Delaware Bay so that we leave the C&D at the start of the ebb.
Here is a story I wrote after a very plesant sail down the bay.
A DREAM BECOMES REALITY
May, 2008
by Dave Nance​
I frequently day dream of the perfect sailing passage, one where the wind is from the optimum direction, the seas in the correct pattern, and the weather mild. This situation seldom happens in real life; in fact, it may happen only once in years, or may never happen. It’s that anticipation that keeps us sailing, looking and hopping for that perfect sailing passage.
It finally happened. We left Rock Hall, MD on Tuesday bound for New York Harbor. The weather forecast was for a cold front to pass over the New Jersey coast on Tuesday night and a high to build rapidly over Cape Cod on Wednesday. As we sailed up the Chesapeake to the Chesapeake and Delaware Canal the wind was light and at our back. We motor/sailed to the canal and picked up a strong flood tide to rapidly carry us to the first nights anchorage at Chesapeake City.
The front came past about 2 AM on Wednesday as predicted. We departed the anchorage at 6 AM to meet the beginning of the ebb at the mouth of the canal at 8 AM. As we left the protection of the canal and entered Delaware Bay the wind was from the north at 15 to 20 kn with gusts to 28. We set a reefed main, joined the ebb and flew down the bay at 7 kn through the water and with the fair tide, over 9 kn over the bottom. We carried the ebb to Cross Ledge before it ran out. At that point the bay is wide enough that the new flood tide had little impact. We easily made the Cape May Canal, squeaked under the bridge with eighteen inches to spare and had a restful night in Cape May. Eight hours of downwind sailing in Delaware Bay is a rare treat on such a notoriously messy bit of water.
Thursday dawned calm with winds forecast to be light and rotating to the southeast as the high began to build. We left Cape May bound for New York City and set all sail in a west wind off the coast and in smooth water. We sailed at 5 kn in beautiful blue/green water and marveled about the weather. By noon the wind began to clock to the southwest and continued to strengthen. By 2 PM it was 15 to 20 kn and seas building. We were now running with reefed main and no jib. Our speed increased to 7 kn and surged to over 8 kn down the larger waves. We were having much too much fun to get any rest in preparation for nightfall.
As dusk came the wind lightened as anticipated and as a precaution we put a second reef in the main before darkness. This slowed us to 4 kn as planned so that we would arrive at the New York shipping lanes at dawn.
The night was beautiful. The high brought in dry air and stars were everywhere and seemed close enough to touch. We counted satellites and looked for constellations. A sliver of moon rose in the early hours of Friday morning and cast a red glow on the water as it rose and turned silver.
Throughout the night Lois and I applied the sleep strategy of alternating naps of 30 to 50 minutes as we had read in Erin Myers article The Sleeping Enemy. Amazingly it worked well. We both stayed alert and were not dead tired when we arrived in New York. (Those of you that read my review of this sleep strategy article know what I am referring to).
We arrived at Sandy Hook at dawn as planned, shook out the reefs and made course for the Verrazano Narrows. Twenty hours and a perfect passage from Cape May to New York. What a treat.
Our next treat is to enjoy New York City for several days.
Hope you can also fill your dream sail soon.
Dave & Lois Nance
S/V ARIEL
Sep 30, 2008
195
Thanks all !!!, we have decided to make a stop on the chessie side for the night and wait for more light. Anymore info would be great as my charts are on my boat and can't get there till Tuesday. My friend is working his charts but I don't want to be an ignorant passenger. I've searched the destinations forum and found much of what you guys have said. Last I heard the wind has shifted against us but how often are they right three days out...
Sep 30, 2008
195
Well we have decided to split up the trip and are leaving Cambridge on Wednesday morning for Chesapeake City. Then leave in the early morning for Cape May. I'm still trying to get my head around the current chart. I'm so rookie. Off the chart richk suggested I get this for thursday
2010-03-25 05:28 EDT -0.09 knots Slack, Ebb Begins
And actually leave a little before that.
Well we have decided to split up the trip and are leaving Cambridge on Wednesday morning for Chesapeake City. Then leave in the early morning for Cape May. I'm still trying to get my head around the current chart. I'm so rookie. Off the chart richk suggested I get this for thursday 2010-03-25 05:28 EDT -0.09 knots Slack, Ebb Begins And actually leave a little before that. ???
I assume that's for CC? The tide at Reedie Point is of consideration too, and probably more important to heed than in the canal. In the canal you fight current, in the DE you'll fight chop and current. As I recall Reedie high is maybe 5 hours after CC? Maybe sleep in some and leave a little AFTER low at CC. I replied to your PM. How much draft does he have? CC basin was dredged in 2004 to 12 feet. Maybe it's still that, but I'd be carefull.
Ariel
Feb 1, 2006
279
Marc,
Here is the latest status of the Chesapeake City entrance that I could find.
08 June 2009
C & D Canal, Chesapeake City, shoaling update
6/8/09
Regarding Chesapeake City, we entered (and departed) at mid-tide with a
5'11" draft maintaining at least two feet under the keel by favoring the
*EAST* side of the entrance (50-75' from the bulkhead). The shoaling
reported is on the West side of the entrance.
Capt. Mike Curreri
USCG 100GT Masters, Near Coastal
Blue Grotto (Selene 5578)
6/6/09
The center of the channel into the basin here at Chesapeake City has filled
in again. A couple of years ago they had dredged it and the last time we
were here in 2007 it wasn't a problem. But yesterday just after low tide we
found about 4 ft. The shoal extends almost all the way to the transient
docks at the Chesapeake Inn & Marina (straight in from the entrance
channel). Several sail boats grounded after we came in - one left and a
couple kept trying and finally plowed their way through and went back into
the anchorage.
Can't tell you yet where the deepest water is - on the east side of the
entrance toward the wall, a USCG tug and work barge stirred up a ton of mud
pushing in to tie-up at the wall, they had a hard time pushing through the
mud. His draft markings on the hull showed a little less than 5 ft draft.
After the USCG tug had tied up, a sail boat made a second try to get in by
staying close to them on that side and grounded just at the end of the wall
where it opens up into the basin.
We will try the west side of the entrance by the town dock when we leave and
see if the depth is any better there.
10/22/08
The entrance to the basin at Chesapeake City has shoaled at the center once again. Depths of less than 6 feet have been reported 2 hours prior to high tide. The engineer at the Corps of Engineers office in Chesapeake City stated that deeper water can be found on the east and west sides of the entrance.
The dockmaster at the Chesapeake Inn sent in this report.
As of last week, the center on the entrance to the cove has 4' of water at low tide. The East side has 6'-7', and the west side has 5'-6'.
Andy Upp
Dockmaster
