sleeping comfort
1,087
Mainship Piliot 34 Punta Gorda
Don't know specifically about a 26 but a good 3" memory form will help any berth.
Aug 11, 2006
1,446
Hunter H260 Traverse City
Very broad topic but maybe if you tell us what you've done already we can help more.
Hunter 26 Illinois
Aft berth
I found the vinyl covering on the aft berth uncomfortable and the sheet slips off or bunches up. I brought the cushions into the house to use as a pattern and sewed the corners on the sheet tighter. Then I made an elastic piece with clips on each end to clip underneath on each side and keep the sheet from moving. I bought a reasonably priced pad with about an inch of foam in the middle. MUCH BETTER!
Aug 5, 2009
9
2 27 HALIFAX ARMDALE Yacht Club
good sleeping habits
Any suggestions on making sleeping on a Hunter 26 more comfortable.
Read poems of beautiful women, or better still have one read poems to you until you fall asleep.
If t hat does not work, get a great bottle of Remi Martin and a cigar.
Nov 7, 2009
67
Hunter 22 bloomington,in
I found a pretty little red head works real good on a hunter 22. I think the same would work on a hunter 26.
Good Luck
Rick
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Picture please
Good Luck
Rick
Rick, not sure I have the whole picture about your response, could you post a picture :)
Nov 7, 2009
67
I have no problem with posting a picture but she does and you know boating season is about to start here in Indiana so she wins again.
Rick
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Just redid the cushions on the boat. You need a minimum of 4" of foam on the "mattress" cushions to be comfortable. If the cushions are not that thick you may be able to add foam underneath and make a better mattress.
