One last post (probably) if anyone is interested...and Vinny's point is most important...oil MUST be FULL. This came from Larry Berlin who teaches at Mack Boring
Original Message Sent: Wednesday, March 17, 2010 10:01 AM
To: Larry Berlin, at Mack Boring
Subject: Maximum heel? Question came up on Hunter Owners Website today that I've wondered about myself. Any idea Larry, what the maximum degree of heeling angle a running (motorsailing) Yanmar 3GM30F can handle? We regularly sail our boats at 15-30 degrees heel. At what point would oil pick-up and any other issues take place. Thanks for your time and knowledge you continually share with others.
This is a common question and there are several answers. All information is only accurate if the oil is at the full mark on the engine and transmission dipstick and the coolant is full.
1. If the prop shaft angle is 8 degrees or less on a parallel drive engine. Constant heel would be 30 degrees or less with peak heel being 40 degrees. NOTE! Peak heel means, The boat is running at up to 30 degrees and hits a wake and heels over to 40 degrees for 10 seconds or less.
2. On a parallel drive, if the prop shaft angle is 8 to 15 degrees, constant heel would be 20 degrees and peak would be 35.
3. If there is an angle drive transmission and the engine angle is O, constant heel would be 30 degrees and 40 degrees.
4. If the engine with the angle drive transmission is installed at an 8 degree angel. The constant heel would be 15 degrees and peak would be 20.
Remember that if you are sailing beyond constant heel recommendations, there is a chance that the through hull sea cock will come out of the water. This could cause serious engine overheating. I hope this is helpful. Larry
