Just mounted new 15hp yamaha 4stk on my 79 H27. I reinforced transom with angle iron bracing running forward and tied in to several areas forming a "box" structure the whole thing is rock solid and 0 flex at transom. The motor is remarkably quite and smooth easily pushing my boat against strong wind,current,and chop to hull speed at about 2/3 throttle in NY harbour. And no engine racket . HOW COME a small,quite,compact motor such as this one as not been adapted for inboard use? I realize traditional inboards gas/diesel have to power an alternater which robs a lot off power under load but the charging system from outboard should be plenty for medium sized boats. cheers frank
