Draining Antifreeze from Yanmars
779
Hunter 35.5 Legend Lake Travis-Austin,TX
It's finally time for me to drain the 3GM30F in my 35.5 and replace the antifreeze mixture. I've read and printed out several articles on how to do it and I know where all the drain petcocks are and that I need to clear out the hose to the hot water heater. What I'd like advice on is HOW do you get the water from the petcocks down to a drain pan? Is it as simple as putting a larger piece if tubing around the tubing hanging off the petcock? Originally, I thought I'd just drain it to the pan under engine and suck that out with a wet/dry vac...got to be a better way. Advice please.
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
I use an oil change pump to suck out all the anti-freeze, I have a dedicated one I use solely for this purpose, it works great.
orion
Nov 19, 2008
52
Hunter legend 35 City Island
The easy way is to insert the plastic hose from the petcock into a plastic one gallon milk jug and drain the antifreeze into it. There is only a couple of gallons. As for the water heater let gravity drain the hose the same way. Then flush the system with a garden hose until you get pure water through the system.
Jan 2, 2005
779
Lee...so you suck it out through where the radiator cap is? Do you feel like this gets it all.
Orion...wish I could get a garden hose to the boat!
Sep 26, 2008
566
- - Noank CT.
Why not just open petcock directly into shop vac hose ? Shop vac should be able to suck it all up wihthout a mess in the pan.
