Building a new dinghy
Ross
Jun 15, 2004
14,693
I particularly like the lines of the dinghy the Roger Long published on this forum. However I have a few questions concerning the scantlings. If I were to build from the thinest plywood I could find and then tile the inside with end grain Paulownia blocks after the manner of balsa cores and glass over the entire structure I think that I could make areas that could be subject to abuse thicker and stronger than I could achive with constant thickness plywood. Is there a down side to this approach other than an increase in weight and cost? The supply of paulowina wood is not a problem. I can get a truck load.
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
I hear plastic bottles filled with CO2 create good structure for boats...or maybe spent propane tanks for grills...
Oops, wrong thread.
Likes: 1 person
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I don't see why that wouldn't work, You'd probably want to taper the blocks so as not to cause a hard edge though. I'd also recommend putting a layer of kevlar cloth down under the glass on the bottom of the boat. Kevlar adds a lot of puncture and abrasion resistance, and will probably make the dinghy far more durable.
May 29, 2009
98
Lancer 27ps Suisun City
Had you considered wet layup over foam cores? Burt Rutan builds airplane wings from it. What in the world is "paulowina wood" ? Do I sense your famous wit coming on Ross?
Ross
Jun 15, 2004
14,693
I lined Bietzpadlin with Airex core from the turn of the bilge to the cabin top from the bow to the companion way bulkhead. So I am a little bit familar with composite comstruction.
Paulownia is those weed trees that have leaves as big as a steering wheel and have rather pretty purple flowers in the early spring before the leaves come out. Any vacant lot or abandoned property seems to attract their growth.
May 29, 2009
98
I've done a little of that myself, mostly aerospace stuff though so I don't really know if that kind of construction is suitable for marine apps.
