So I am in the middle of my re-wire project when it gets a little warm up here in Maine, especially for this time of year. All of a sudden I notice a couple of drops of diesel in my engine compartment, just as I had seen at the tail end of last season.
At the end of the season I cleaned it and put some paper under the engine, secretly wishing that is where it was coming from, though I really knew it wasn't, but all winter NADA, no drips. Good, problem solved!
But wait, it was only temporary, until the weather warmed up and the fuel tank again began to leak.
I don't have a good explanation other than the thicker diesel viscosity in cold weather or sludge mixed with water that froze, as to why it did not drip all winter, but it did not and now it is back..
So yesterday evening I disconnected and removed most everything on the engine, motor mounts, fridge compressor, hoses, water heater, fuel lines, Racor, gear box etc. etc. on and on. I then used my main sheet and an old boom vang with a 4 X 4 across the companion way to lift the engine out of the bay and plop it in the galley so the tank could come out. Tim R. came over for the final "plop" of the engine and to help disconnect a hose I had missed.
It all went quite smoothly and the tank is finally out of the boat and a new one is being made. It will only cost 1.2-1.4 boat bucks, plus hoses etc. and I should be back in business..
Here I come:
The engines temporary resting place:
The pin hole that caused all this BS:
All in all, from start to finish on the removal, it took me about an hour and a half to disconnect everything, set up the hoist and get it prepped for removal. When Tim showed up it took us about another hour to get the engine and fuel tank out. So 2.5 hours is not to bad. Going back in should take a little less time, except for the re-alignment. The longest and most time consuming aspect was the removal of all the hoses. Cold hoses don't like to let go of hose barbs...
Oh well it gives me a good opportunity to clean under the fuel tank as it was quite nasty and had been hidden since 1979.
The new tank will have three supply and return fittings as opposed to just one set. One of them will be for the engine, another for the polishing, recirculation system and one for a cabin heater..
It's always something with boats.....:cussing:
P.S. This boat has been using Sol-Tron/Star-Tron for over 12 years. The PO used to get it from Europe, as Sol-Tron, before it was marketed here as Star-Tron. I continued the use of the product. When I get the old tank back from the shop I promise to cut it open and see if the "claims" are true? I will be surprised if this 30 year old tank is totally clean. I have not really had any problems but something ate that hole at the low point of the tank and it was not sitting on the hull, but rather suspended with air circulation at the pin hole area. My guess is that it came from within..
Here I come:
