Halyard
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
shermandr, good for you in realizing the benefit of high modulus line. There's a simple solution to your problem. Insert a length of line cover or core inside the core of your line where it is used in the stopper. This will give the need diameter for use in the stopper.
Jun 1, 2004
8,351
I actually would sit on the cabin and pull the genny in by hand and could feel the difference. I've been debating buying a car for the track and using a snap shackle to the clew. I would find a way to tension it without releasing the original sheet because I have blocks like Hermit's that only take a single line.
As soon as I find a thimble, I'll splice my line. Thanks for the websites. That rumble wasn't another earthquake, just someones foot coming down.;)
Another thing you can try is improvising a barber-hauler... a simple clip attached to a spare line can be attached to the loaded headsail sheet then run cross deck to the cabin winch. You can the pull the sheet athwartship to bring the clew closer inside. If that has a positive effect, you can invest in a snatch block, install a more permanent barberhauler or put a car on the inside track and use the two sheet system. The two sheet system will be easiest and cheapest. You leave the outside sheet attached, just tension the inside one while easing the outside to bring the clew inboard. They work together.
Another quick comment... guys who race, like Alan, are good sources for rigging problem solving. Spend some time perusing the racing oriented store sites like www.apsltd.com you'll find lots of great ideas you can apply to your own boat that will make it more functional and fun to sail.
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Thanks Joe, that seems like what I've been thinking. I was told my budget just dried up and I feel the heat on the back of my neck.
:laugh:
All U Get
Why doesn't my quote go in a little box? :doh:
3,502
- Telstar 28 Buzzards Bay
cause you deleted a [/quote]
:laugh:
All U Get
Oct 2, 2008
3,815
cause you deleted a
Stupid little box. Thanks for all the replies. I'm using 7/16 because it's sitting on the box with the spinnaker and it's easier to pull when these old hands get cold. I'm pretty sure it will all work. ;)
All U Get
Jun 1, 2004
8,351
All U Get
7/16 is fine cause you're probably running the spin halyard to an external, swivel block mounted on the crane in front of the forestay..... I highly recommend you do not try to run the halyard internally. A spinnaker halyard run outside the mast can be jumped by the foredeck crew... way faster than standing in the cockpit... so run it outside to a cleat on the mast, and/or back to the cockpit so you have some crew options.
Dec 4, 2008
264
Other people's boats - Milford, CT
You can jump an internal halyard just fine. Just put the exit box above head height. In fact, it allows you to get more leverage that way, by pulling out and and down.
Of course external is less work and less money.
As a part time mast man, 7/16 is a very generous size for a Catalina 30. 5/16 would be more common. If that fits your clutches.
