I discovered that my main fuel tank is just a few inches too low for gravity feed to the Newport diesel cabin heater I'm installing. I don't want to be dependent on a pump or have to listen to it clicking so I'm having a small gravity tank made.
I have a fuel polishing system on my boat that is circulating fuel whenever the engine is running.
http://www.rogerlongboats.com/FOpolishing.htm
So, how cool is this?
The 1.5 gallon tank is simply inserted in the line that runs from the polishing system back to the main fuel tank. It thus fills automatically with just filtered fuel when ever the engine is running and this fuel is constantly renewed. If I run the stove for a long time and need to refill the tank, I just turn on the polishing pump for a few minutes. No lugging Jerry jugs around, no worry about over pumping and spouting fuel out the vent.
Although the tank is unlikely to overfill, the vent does need to have a check valve on it just in case. The Forespar replacement cap and duckbill valve for their anti-siphon loops can be screwed onto a 1/4" NPT x 1/4" tube compression fitting like the parts were made for each other, which, maybe they were.
The length of copper tube will stick up without support to the highest point I can reach with it up in the cockpit coaming. The air bubble in the tube and the top of the tank should prevent oil from ever reaching the little joker valve.
