What exactly goes on underneath that box?
While doing some work, I noticed a small trickle of water coming from underneath the box. I guess I am claiming ignorance as to the source of water. Is that downstream of the impeller, after cooling, then out the transom? If so, can one drain that box to work on it in the water, or does it have to be on the hard? I think there is a petcock aft on the box, is that the drain source, and if so, how much is in there?
I know it is a long list.... Thank you in advance for tackling this one!
What can of worms am I opening here.... ?
BTW: 1991 Cat30 MkII
