Some more info
For those of us who have been following alternators and power requirements for quite some time, the HP used by an alternator, regardless of what size the alternator may be, is based on the energy the alternator puts out. That amount is determined by the load imposed by the regulator and the acceptance of the battery bank. Most 400 ah house banks, even if reasonably discharged, won't require more than 50 to 60 A based on the battery acceptance. Therefore, even our 100A alternator on our 360 ah house bank when depleted overnight ot below the 85% charge level will only put out 50 or 60 A upon startup based on the bank acceptance. We have also discussed many times that a 100A alternator will have to work less than a 60A alternator to provide for this load. Accordingly, then, the larger alternator draws no more power from an engine for that same load, but may last longer because it is not working up to its total capacity. Running a 30 or 20 hp diesel engine at low rpms to ONLY recharge banks has always been know to be eventually damaging to the engine. Use your engine to charge your house bank when the engine is used to propel the boat. Use another source, like solar, to charge the banks instead of just the engine. For most of us weekend warriors, the simplest answer to this is to install as large a house bank as you can (400 ah if you have a fridge) and you can sit for two nights at anchor before you HAVE to start your engine for DC power. Then you motor home and plug in. Each boat gets used differently, of course, but those are the basics. Staying plugged in all week isn't good for you batteries, but neither is leaving the boat unplugged with partially discharged batteries either. Again, a simpler solution is solar: not keeping the boat plugged in helps the batteries (unless you have a charger that'll turn itself off when the bank is full) and avoids potential damaging from bad dock wiring or lightning. A boat is a compromise, but basic battery technology and battery charging is not, related specifically to alternator charging.
