I was an aircraft mechanic in the Navy. I got very extensive corrosion control training. (Salt water, stack fumes, and aluminum don't mix). Never use steel wool on aluminum. It embeds steel into the soft aluminum, then the steel rusts! You also get dissimilar metal issues.
Scotch Bright was invented to fill that role.
