Heater - can you still have heat to the cabin after water is hot enough? I visualize the water boiling ..
Ross above figures 2 - 3 hours of heat after the fire is turned off which seems about right. The boiling issue was a factor in choosing a large surface area, uninsulated tank. I don't expect to run this system unattended or overnight. If the tank does get too hot, or just up to a comfortable hot water level, and I still want primary heat, I'll start dumping heat in to my main hot water tank. It will take a few hours for that to come up to temperature. I don't intend to run this system unattended. If I hear steam bubbles, I'll start the circulation pump. I plan to mount a thermometer on the tank.
The primary purpose of the bulkhead tank is actually to cool the stove water coil and keep it on "standby" without having to have a circulation pump running whenever the heater is on and not waste the heat as a tank hidden away in a locker would do.
concerned that 1" dia vertical will not resist person falling against it athwartships.
It might not. Falling forces are hard to predict but a falling person will bend a lifeline stanchion. Easy to replace S.S. tubing. Hard to arrange chopper evacuation.
The full height stanchions of the same material I have now feel pretty stiff although the are supported about 1/3 of the way up. The S.S. handrail material is pretty stiff. I'll re-assess when I get a piece of the stock in my hands. Table leaves will be supported on the removable stanchions I have currently. They will go under about the middle of the leaves which is a bit of a pain from the leg standpoint but is quick and easy and gives good support. They have nice heavy, sharp, rectangular flanges at the table end and are just the right heft and length for repelling boarders so I want to find a use for them to justify keeping them on board
The table design and hinges have been revised since you may have seen it so that the leaves can be raised 30 degrees and to be more compact. This gives the option of support from overhead chains so that it can be angled for a long tack. It would be a simple matter to make this a swinging table but they usually don't work out very well in small boats.
