I-Pad Chartplotter
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
Get ready for this idea.
Take yer newfangled "I-Pad" and plunk in some charts. Then plug in a GPS and presto!
A portable large screen chartplotter to use while at the helm...or anywhere you want for that matter.
I love technology.
Jun 2, 2004
5,802
Great idea! In this morning's Doonesbury comic the wife hears her husband going on about all the features of the now I-Pad. "It makes perfect Panini's! too", he crows.
Sep 12, 2009
17
Currently looking Sail Cranston, Rhode Island
You might not even need to plug in that GPS, looks like it has it built in......
GPS and navigation features:
Built- in GPS chip and accelerometer.
Built-in magnetic compass.
Apple claims the iPad will run all existing iPhone apps, including navigation apps. However, the screen size will remain iPhone-size until developers adapt their apps for the larger screen.
Google Maps runs full-screen on this device, which makes it more like the Google Maps experience on a good PC or laptop monitor
Since I work in IT, I may need to pick one up to do some "research"
May 23, 2004
3,319
Yep....but what is the pricetag on this item? I have a feeling that it will be expensive!
Sep 12, 2009
17
Right now it's $499, it will probably stay there until the next model comes out.
11,760
To bad its about as water proof as a paper towel :)
I have been using tablet PC's now for about five years every day for my job and I can assure you they are NOT water proof nor visible in the day light. Even in my car on a bright day the screens are hard to see. I can't imagine that the iPad has a daylight vis screen and is waterproof. You can buy a waterproof daylight vis plotter for less..
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I wonder if someone can tell me the advantages that justify the expense of a chartplotter over a computer. Many people have plotters, so I assume their cost is justified. In evaluating this, I want to make sure I understand the pros and cons.
I understand plotters are largely waterproof and may interface better with other sensors to combine several functions, such as wind direction and depth readings. I'm sure there is a great deal more.
As to the Ipad versus the computer wonder if the Ipad is more water or vibration resistant than a 12" notebook. What other advantages does the Ipad present over a small notebook computer? Is the screen more visible in sunlight or an angles? Does it interface more effectively with gps than a pc does?
Ross
Jun 15, 2004
14,693
Toys! people will always pay more for the things they want than for the things they need.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
I've been using my Acer Netbook as a chartplotter for some time now. Load in the charts, run your favourite Nav program (unfortunately in Canada it pretty much has to be Maptech if you want to see your BSB4 charts :( ), plug in a cheap GPS and voila!
Advantages over "conventional" chartplotter:
1. CHEAPER
2. bigger screen
3. you can play solitaire on it at the same time (or if you have a cellphone digital "stick", surf the web)
4. (If you use a real llaptop rather than a netbook) you can also use it for watching DVD movies.
Disadvantages over conventional chartplotter
1. seriously not waterproof
2. VERY hard to see in sunlight
3. more wires, gadgets, boxes, etc.
I use my "chartplotter" GPS usually to display speed and course over ground, dist and bearing to waypoint, and battery voltage in NICE BIG LETTERS that my old eyes can see from anywhere in the cockpit.
druid
Oct 2, 2006
1,517
Jboat J24 commack
My 5" Lowrance 3550C has everything you need with 0183 and 2000 was 500 dollars can be seen in ANY condition all while not blinking about having saltwater and rain as its best friend
Sep 20, 2006
2,953
Depends on where you sail. When I was on Lake Ontario, never needed one. Motored out of the marina and sailed away for hours with no worries.
Now, I wouldn't think of going anywhere without it. Red buoy almost off the port, green buoy upper left, green buoy mid right, and the light blue is rock beneath the surface that is not visible. The area ahead is clear wide open water. Wind typically is from the west, which makes sailing through this area fun at the least. It can be done from charts or computer at the nav table, but I like to push as far as I can get and its not fun without the plotter.
615
Morgan 415 Out Island Rogersville, AL
It kills me that all the marine manufacturers use proprietary networks. It would be wonderful if they made components that spoke through a usb-based network--or better yet, a wi-fi wireless network. Computers are destined to replace the plethora of instruments that are currently out there. The computer can live down below and display the data to multiple touch screens around the boat. Mil-spec displays will be able to withstand the weather.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I'd point out, that in favor of the iPad is its relatively long battery life and the fact that the Navionics navigation app is already out there... However, I think most boaters would be far better off with a small chartplotter rather than using the iPad. The chartplotter would be a single use, less prone to failure and waterproof device that would cost less than the iPad.
BTW, only the more expensive "WiFi + 3G" model of the iPad has an integrated GPS IIRC. So, if you don't want to add a bluetooth GPS to the budget, you're looking at $599-699, not $499...which is for the WiFi only model with no GPS.
donker
Dec 2, 2009
32
Beneteau Moorings 38 San Francisco
Agreed on the problem we've had with proprietary systems, but am heartened in my current research of upgrading autopilot, GPS, and several other instruments that the adoption of NMEA 2000 standards by most of the big manufacturers in 2007 is allowing much simpler, "open architecture," "best of breed" systems. For example, I can mix a Simrad autopilot with a Garmin GPS and Raymarine MFD as well as my flat screen TV and tie in a new Furuno digital radar and the engine instruments for my new Yanmar (sore subject) and they can work with each other reasonably well over a NMEA 2000 wiring backbone. Not quite USB, but getting there.
