Has anyone that had acutal damage from this been able to recoup any monies from Catalina?  I emailed them two weeks ago and have not yet received a response.
								No and I did not like the answer I got from Gerry on this. I sold my boat. We sailed for about ten hours in 30-35 knots and the bulkhead worked itself into the hull so hard it was crushed in spots and the whole thing was cocked and some screws bent. On the exterior you could see a slight hull deformation..Has anyone that had acutal damage from this been able to recoup any monies from Catalina? I emailed them two weeks ago and have not yet received a response.
As I understand it there is/was a bulkhead burning issue and there is also an issue with the forward bulkhead being a little short (or it is the mast support?). Aside from all the Universal/transmission and shaft alignment problems. I am feeling pretty lucky as I don't think I have experienced any of these.We sailed for about ten hours in 30-35 knots and the bulkhead worked itself into the hull so hard it was crushed in spots and the whole thing was cocked and some screws bent. On the exterior you could see a slight hull deformation..
Frank told me they had a fix and then never called back even after multiple calls. When I called and spoke with Gerry I was told this was indeed a noted problem and that we would have to work through warranty. Frank is warranty and he never called back nor did I get reimbursed for the deck void repairs I had done. I finally gave up. From what I was told by Gerry this only affected a "few" of the early hulls but mine was a 2005...![]()
When I had my issue Gerry & Frank swore it was not an "issue". I did not require the compression post spacer like the early ones did.As I understand it there is/was a bulkhead burning issue and there is also an issue with the forward bulkhead being a little short (or it is the mast support?). Aside from all the Universal/transmission and shaft alignment problems. I am feeling pretty lucky as I don't think I have experienced any of these.
Not what I'd consider rough enough to cause this kind of issue. It was short & steep but not over 5 or 6 feet. I sailed my C-36 in rougher and never had a problem like this. I never really pursued it further as I was selling the boat anyway. I did manage to get the bulkhead to sit nearly straight again when it was on the hard. I initially though it was perhaps cut wrong but then was told this could not happen.Had not head that one before. How rough was it? They do advertise these as a coastal boat, but I can't imagine that kind of problem, even in really rough seas.
