I posted a couple of months ago about the blister problem I've got on my 36' Hunter. Just thought I'd repost on ask all sailors. I've contacted Hunter about the blisters and they say they will cover the repairs. As you can tell from the photos there are various sizes of blisters and are all under the gel-coat (there are a lot more than show up in the picture).
I asked the Hunter tech support what the repair technique would be. He told me that they would have to take a dremel tool and clean each blister out and then epoxy. Seems like this would be a nightmare because there are hundreds of these small blisters. I'm concerned that Hunter will balk at the cost of repairs and I don't want to be without a boat next summer if the repairs are too time consuming. Is there another technique for repairing the smaller blisters? There are some larger ones that squirt water when popped but there are also several hundred of these smaller ones.
I've searched the various sailing forums but can't seem to find any info on repairing the small blisters (just the larger water filled). Trying to get a handle on how much the repairs should cost or what the best technique is. Hunter mentioned peeling the gel-coat was probably not an alternative due to cost.
Any insight would be appreciated.
