Ericson 28 survey...your thoughts please.
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
Ericson 28 survey... Closing this Saturday!
Another one gang. Looked at an '87 E28 today. I did a complete survey sans the moisture meter because of weather. This boat is in good shape except for the bottom paint and cutlass bearing. I couldn't tell if the rudder has to be dropped to remove the shaft and/or the bearing can be replaced with the shaft in place since you couldn't score it to loosen it before removal.
The E28s are said to be "a bit tender". Please define that for me.
I was very impressed with the build quality I read about and witnessed. I like this boat and am a fan of a fractional rig as I currently sail one.
Oh...the mast needs some care and new paint. I would assume it is epoxy paint?
Thanks in advance.
Rob
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Most 30ish foot boats are described as a little tender. That term seems to have devolved to describe any boat that develops heel under 20 knots of wind. To me the difference is in how the boat behaves then. My boat will heel, but then hardens up at 15-20 degrees and behaves predictably. If you can deal with it you can sail it all day at 20 degrees.
Mast painting is a big deal. Most masts from the 80's are anodized. Mine is black and has been touched up. It doesn't look bad, but at some point I will have to tackle it. Go for it if you are up to it and the price is right. If were buying a boat with a mast that really needed painting I'd want at least $3000 off the price if I felt the owner wasn't making an allowance for it. Your yard should be able to do the cutlass bearing without removing it. The tool is very expensive. You can try to make one, but it is a challenge. The tool to remove one when the shaft is out is cake to build. I replaced everything myself and it is worth the learning experience to do...but uncomfortable on a small boat. I would have bought an Ericson in a heartbeat if I found one in good shape at a good price. I really looked hard at the 29 and called about a few 32's, but tough to find in good shape. The 30 was a bit pricey compared to my boat and hard to find.
Sep 27, 2008
95
Catalina 30 Lake Champlain
Rob, we recently moved up from an O'Day 23 to a Catalina 30. We looked very seriously at a 1983 Ericson 30. After seeing the boat, we did a lot of research on Ericsons and communicated with some owners. We were convinced that they deserve their reputation as well-built boats that sail well. The owner of the one we looked at clearly loved the boat and described her as "spirited" under sail. The quality of the boat at impressed us. Unfortunately, the boat hadn't been maintained and needed too much work for the price, so we passed on it--reluctantly. But after seeing that boat, Ericsons were near the top of our list. We just couldn't find one in good shape that was also in our price range.
Good luck.
Bob
Jun 9, 2008
1,860
- -- -Bayfield
Generally Ericsons are well built vessels. They did make a plus (+) series, which were more performance oriented with better, more efficient keels and a more powerful sail plan and also spiffed up the interiors more. Not sure if the E-28 had a plus side to them or not. All in all, they were built for crusing and the Ericsons, in my opinion, were not really keen racing vessels in comparison to some other brands of the same vintage, but they sailed well and were built well. I thought they were aesthetically pleasing to the eye both inside and out too.
Regarding the cutlass bearing, there are a lot of things to do to free one up for replacement before having to remove the shaft, but, if you have to remove the shaft, then so be it. It is not the end of the world. Sometimes a shaft will slip by the rudder once the prop is off too.
Regarding painting the mast, epoxy is not the paint you would use. Epoxy is best below the water line because it is very water proof. But, it does not hold up to the sun as well as a Linear Polyurethane product. It will oxidize much faster. I have written detailed instructions on painting a mast with Awlgrip in earlier posts. Since it is aluminum, it requires etching, washing and two different kinds of primer before the topcoat color for a professional, lasting job.
I would think you should be happy sailing an Ericson 28.
RichH
Feb 14, 2005
4,773
The 'tenderness' of such relatively narrow boats is really 'initial tenderness' wherein the boat will begin to heel with little to moderate wind pressure (on the sails when beating) until it reaches a relatively constant heel angle where it will then 'harden up' and want to remain at or close to that heel angle. Boat of this type usually 'harden up' at about 15-20 degrees of heel.
The E28 is a well balanced and well mannered sailboat, enjoy!!!!!!
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I have several friends who own e 29s and have been aboard and sailed them. I like the boats and the ones around here have held up very well over the years.
RobG
Jun 2, 2004
337
Thanks all!
I completed my survey today laying out all of the sails and checking them out. After the first going over of the boat (three hours) I took a break for a few days and "took off the rose colored glasses". I did another going over (two hours) and combined my lists from both. Then another couple of hours today. She's still worth making an offer minus the expense of some issues I'm getting estimates on. I've always done all of my own work but for this offer I don't want to deal with it and shouldn't have to. We'll see how it all pans out.
Rob
Aug 16, 2006
281
Ericson 32 Oregon coast
I had an Ericson 32
It was extremely well built. Very solid. I really liked the keel being integrated into the hull. The interior space was a bit less than similiar sized boats but it was enough for us and so enjoyed the extra performance. There is a tendency for the E32 & E35s to want to wander ( fishtail ) going down wind ( running and broad reaching ) more than other boats so I had to get used to being more dillegent on the helm going down wind but it was only a minor inconvienience and I was extremely pleased with overall performance.
I would say that if you like the look of it and are good with ithe interior you are going to love it.
higgs
Aug 24, 2005
3,738
Nothing can replace a professional survey by a qualified surveyor. If you are doing your own survey, it is like being your own lawyer.
Dec 2, 1999
15,184
Higgs is correct. And don't forget no professional survey, no insurance!
There is absolutely nothing wrong with doing your survey to determine if you want to pay for a professional first, but ultimately you need a pro to get the document for the insurance co.
Tim R.
May 27, 2004
3,626
No necessarily true.
That all depends on how you insure the boat. If you want a boat rider on a homeowners policy(typical for smaller boats), most insurance companies do not require a survey. If you insure with a "yacht" policy you will need a survey.
I did my own survey on a 28' Pearson and insured as a "boat". My Ericson 35 was surveyed by myself and then a pro and it is insured with a "yacht" policy.
I am a big proponent of profession surveys and would have gotten one for the Ericson regardless of insurance requirements.
Aug 16, 2006
281
My previous post was give as a guide to help
narrow down your choise. I absolutely recommend that you get a professional survey done if you are about to select a boat. The piece of mind alone is worth every penny.
RobG
Jun 2, 2004
337
Absolutly getting a pro survey
I've seen some walk away boats. This one deserved a through look and I did one. Once I'm satisfied that it deserves a pro surveyor I'll contract one. This boat, I believe is a "diamond in the rough". I'll start the offer process next week and if we can agree on a purchase price a surveyor will be contacted.
Thanks all...
Rob
higgs
Aug 24, 2005
3,738
I think you are doing the right way. You will be happy with your new boat.
RobG
Jun 2, 2004
337
The closing is this Saturday morning!
:)I'm happy to say all went well except... Nothing new turned up in the pro survey compared to mine except one observation. The surveyor, after looking at the stuffing box hose casually from afar, said to not only replace the hose clamps (this was on my list) but the hose. I thought the hose was fine and doing this really makes things much more complicated than replacing the clamps and re-packing which I had planned. With all of the chatter about rusted couplings being totaled when removing the shaft from them I'm kinda bummed. :cry:
What is the "normal" replacement cycle for these? Is it standard for a surveyor to automatically call this out? He was really great otherwise.
Other than this one issue I'm pretty psyched. It's gonna take some scrubbing bubbles and repair/replacement/improvement but all of I expected after my survey. As I said before she's a diamond in the rough!:D
Thanks again for all of your responses.
Rob
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
:)I'm happy to say all went well except... . The surveyor, after looking at the stuffing box hose casually from afar, said to not only replace the hose clamps (this was on my list) but the hose. I thought the hose was fine and doing this really makes things much more complicated than replacing the clamps and re-packing which I had planned. With all of the chatter about rusted couplings being totaled when removing the shaft from them I'm kinda bummed. :cry::D
Rob
First, congratulations... It sounds like you are more excited than bummed, and you should be...just remember that all boats will have some issues. As far as the stuffing box hose, did the surveyor point out some specific issues with the hose? If it were me, I'd consider taking the shaft off and just replacing the hose and cutlass bearing both at the same time (hopefullly you don't need to drop the rudder). As far as rusted couplings...I'd start by applying PB Blaster and letting that penetrate before removal (also, a couple light taps with a hammer might break loose rust and let the PB Blaster penetrate better). Good luck.
RobG
Jun 2, 2004
337
Tim R., Stephen,
I sent you an e-mail via "Contact us" of the True North web site.
Thanks Stephen I am excited. I am fully aware of the continuous need for maintenance and expected it after my survey. Apparently the previous owners (of 5 yrs) were not. Nothing really damaging though. Here is my posting from the Ericson site:
The first "system" to go this winter is the sanitation. Everything goes except the head. It stinks pretty badly. I don't need the overboard option so I'm getting rid of all the hoses and "y" valve, Gusher pump (which I'll keep and re-build), holding tank ect...The system will be very simple with a short head hose to the holding tank, vent and pump-out. All very short lengths.
As for the stuffing box I haven't decided on the PSS or sticking with the conventional with Gore packing.
Also on the service list:
Bottom job
Cutless
Hatch re-build - they are really crazed badly
Lube all seacocks - some are really stiff
Sail service
Lots of scrubbing bubbles. In some areas it's really moldy between the hull liner and hull.
The rest is all acceptable enough to chip away at when time and $$ permit.
Improvement list for this year (I hope):
Retractable lazy jacks
Rigid Vang
New anchor gear (Manson & chain)
Different spinnaker rigging
At lease a couple of Sensibulbs for the cabin
Oh yeah! Selling my current boat!
_____________
It will all be worth it the first time out!
Rob
Tim R.
May 27, 2004
3,626
Got it. He is a reputable surveyor and I would do as others have suggested. Remove the shaft and replace the log hose and strut bushing. That log hose is a special type of hose. Some feel it is ok to use automotive type heater hose but it is not. The log hose has reinforcement that holds up much better against the twisting force of the stuffing box.
