I'm going to put an access plate in the base of my mast to get at the connectors so I just cut the Garmin network cable for radar and will have to install a coupler. This will require putting new modular plugs on and there are two different cable ends. Get it wrong, and the display won't know that the radar is there.
I had to sit down and draw this out. It looks like a lot of work but CAD actually makes it quicker and easier than scribbling on the back of an envelope.
There is an "A" and "B" end to the data cables and they are not marked. You have to look at how two of the wires are reversed according to this table:
Here is the standard, single cable setup with "A" plugged into the radar. It will also work with the cable reversed.
The cable that came with the radar wasn't long enough in my boat so I had to buy a 6 foot extension cable and a coupler. I went to the boat today and determined that I had put the "A" end into the chartplotter display unit. I also deduced that the coupler must have the wires crossed over inside it.
Note: I've shown plugs into the connectors with the 1 pin position reversed from it's actual orientation in the units so that the connector schematic will show a crossover instead of appearing to be straight through.
I could have put the extension cable in the other way or still reverse it as shown here:
Here is the coupler I have to add. I have shown an "A" end coming out of the deck because I would like to be able to plug the radome in here for testing when the mast is down and elsewhere.
Note that this means I will now have an "A" end coming out of the mast. Should someone ever attempt to test the radome mounted on the mast by plugging a display unit into it while it is off the boat, the radar won't work and this could lead to misdiagnosis such as thinking the cable is compromised.
By taking the minimal trouble to reverse the extension cable as shown here, I can have consistent cable runs and ends all the way through.
I think it's worth doing and something to think about if you are doing a new installation that involves extension cables and couplers.
