- Jan 22, 2008
- 198
I wonder if anyone has replaced any part of the standing rigging on a small (26' or under) trailerable boat with high tech HMDPE line?
Amsteel Blue, for example, is advertised as being just as strong or stronger than stainless wire of equal diameter at 1/7 the weight. 5/32 Amsteel Blue has a tensile strength of 4000 lb compared to 3300 lb for 5/32 stainless wire. 3/16 Amsteel has a tensile strength of 5400 lb and sells for only $.48/ft. It is very easy to splice, and a couple of thimbles are much cheaper than mechanical fittings for wire rope. On the surface, at least, high tech line seems to be a cost effective alternative to wire, especially for runners and backstays. I don't think I would use it as a forestay with a hanked on jib, though.
I'm not saying that Amsteel or other Dyneema lines are necessarily the best choice; Spectra may be better, or PBO, although that seems outrageously expensive for a small boat. What I am asking about is the idea of using high tech fiber instead of wire itself. I know that it has been done on larger boats. One real advantage on a trailerable boat that I have not seen mentioned is the ease of handling when the mast is down. Line would be much easier to handle and secure to the mast for trailering than steel cable that has a mind of its own. No worries about scratching the gel coat with errant stays or kinking the wire trying to get it bundled up.
Comments?
Comments?
