Fuel Expiration Date...?
123
Columbia Yachts C22 Long Beach
I filled up my gas tanks (2 - 5 gallon portable tanks) with a 40:1 oil mixture in July and have not sailed since. I'm planning on going sailing after Thanksgiving, but I want to run my outboard a bit before I get down to the ocean (my boat is a trailer sailor).
Is my existing gas stash okay for now?
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I would guess it probably is ok, as cold weather is what causes most problems with stored fuel. But there is only one way to find out for sure.
Oct 6, 2009
97
Custom Bluehull Kennesaw, Ga.
you should be fine, as long as no water leaked in. I had gas set for almost a year, motor started just like always.
zeehag
Mar 26, 2009
3,198
the shelf life, as it were , for mix is 2-3 months...place sta-bil in it and pray--freshen it with more and see if you still have fuel system lol...should be ok with sta-bil in it......
15,184
I have used fuel that is 6-9 months old. As long as it does not sit in the carb and plug up everything it should work. Mix in some fresh oil/gas to perk it up.
Catalina 380 new bern
Sta-bil?
How does sta-bil work? is it burned up in the combustion chamber?
I have had gas and diesel last as long as 2 years in tanks and it worked just fine.
Cole
Nov 9, 2009
5
Macgregor 26X Florida
gum
The IMPORTANT part...carb....I ALWAYS disconnect line/shut off gas AND run the motor till it stalls-out, and/or squirt some Marvel Mystery oil while it's still running (smokes up thru exhaust..) ....then also keep sta-bil in the tank...
I see now
Cole
I see now, Sta-bil is ethenol.
I did help a girl replace her fuel filter on her diesel Mercedes after she ran bio-diesel and the resins and junk that were in the lines clogged the filter. She said is was the 3rd time it was replaced in 2 weeks. I never liked additives, or snake oil
Cole
Oct 2, 2006
1,517
Jboat J24 commack
Sta-bil is aromatic naphtha 90% ,naphthalene 5%,and ld50 :)
It is one of the older snake oils and seems to ?
Dec 2, 1999
15,184
The junk in the filter from running biodiesel is normally the cleaning of the crap that was in the fuel system and tank.
Biodiesel can be a good way to keep your system clean, but if it is in poor shape can be problematic for a period of time.
walt
Jun 1, 2007
3,556
I guess that humidity and exposure to humidity would influence the shelf life of gas?
I wonder why cold weather would affect gas life?
I need to store gas in a place which can get very cold but is also very low humidity. Seems like I wouldnt have much problem (also using some additive).
Mar 3, 2003
710
Hunter 356 Grand Rivers
Use Stabil
Year before last I ran out my 4HP Yamaha as usual for winter storage. The next summer it started ok but the carburator jets were restricted and I had limited power for the dingy. I tried carb cleaner, additives, etc and couldn't get it to clear. Last winter, I had it repaired and it works fine now - jets were clogged. Mechanic said they have a lot of that now since ethenol is added to gas. I use stabil now and have had no problems at all. I use it in all my leaf blowers, weed eaters, rhino, etc. Ethenol gas is not as long lasting as the old stuff!
Catalina Capri-22 Lake Geneva WI
Old Gas
You obviously have a two stroke. If you put have used Stable or equivalent in it should be fine, but it is only 5 gallons, so why not be safe.
New 4 strokes are much more fuel sensitive. My 9.9 Mercury starts acting up after 6-8 weeks. They run so lean that they are very dependent on fresh fuel.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I'd point out that it really depends on whether you're using an ethanol blend or an MTBE formulated gasoline. The MTBE-based gasoline has much longer shelf-life, since the ethanol has a nasty habit of absorbing water from the atmosphere and once the water content reaches about 1.5% by volume, the alcohol/water will separate out, leaving you with what is effectively about 82 octane gasoline.
Stabilizer helps, but sealing the tank well is more helpful IMHO.
Hunter 41 GERMANTOWN, TN.
I have stored gasoline in plastic containers with stabalizer added each spring for up to three years. I keep 20 gallons stored for use in a generator in case emergecy power is needed. The gasoline is rotated out every three years and always cranks the generator, lawn mower and automobiles.
Jun 15, 2004
18
Rebel - woodland hills, Utah
Storage life depends on conditions and use of stabilizer. Fuel stored in hot environment degrades rapidly, especially if left in fuel lines and carbureter.
Gasoline is blended by refiners for locality and season. Your July fuel is not the same as that which you would purchase in November.
I have had enough fuel problems with outboard motors that I would burn that July fuel in my car before I would risk it in my outboard even if it contained stabilizer (which does work)
Some diesel engines are also very sensitive to low quality fuel.
Oct 2, 2006
1,517
Jboat J24 commack
Well
It also depends on were you live as many places they still get 100 % gas like upstate NY vs Downstate which gets the blend
Apr 16, 2008
9
Catalina 36mkII Grapevine
Why take a chance. Dispose of the gas and move on. Of course that brings on another problem. How do you get rid of the gas?
Apr 12, 2009
101
Hunter 1996 hunter 40.5 Green Cove Springs FL
old gas
you can tell by the smell-old gas has an odour. I shut off the fuel or disconnect the fuel lines then run the engines until they run dry. Seems to work north of the 49th. With lots of sta-bil
