I'm sure most people who visit this site have real names. It would be nicer to talk with people who would like to share their real names. But I digress.
Terry Cox
And most people register or log in..
There are many, many reasons an individual may choose not to use his or her real name on-line.
Some take privacy seriously and I know of a few members who have been on the receiving end of internet stalking, some may also work for companies that ask their employees to keep low "google profiles" (as mine does), some may post here during work hours and want to remain anon so they don't show up in a google search as posting during work hours, and some of us just do what is safe internet practice and use a screen name.
How would Higgs question change any if he used his full name on-line?
Terry you won't even log in as a registered user, despite having an active account,
yet are frustrated with others for using a screen name? To each his own. We don't discriminate here at SBO and everyone is welcome to post here how they feel comfortable.
You choose to post as "guest", Higgs, myself and the vast majority of the registered usesrs of SBO post using screen names.
Re: 5200
Here's some more info on the product that may help.
"Limitations -
- Alcohol should not be used in preparation for bonding as it will stop the curing process, causing the adhesive to fail..
- Heat resistance - Due to the decreased value in bond strength at elevated temperatures, we do not recommend use of this product above 190°F (88°C).
- Do not apply at temperatures below 40°F (4°C) or on frost covered surfaces. Do not apply at surface temperatures above 100°F (38°C).
- 3MTM Marine Adhesive/Sealant 5200 is not recommended for use as a teak deck seam sealer. Extended exposure to chemicals (teak cleaners, oxalic acid, gasoline, strong solvents and other harsh chemicals) may cause permanent softening of the sealant.
- 3M Marine Adhesive/Sealant 5200 is not recommended for the installation of glass, polycarbonate or acrylic windows that are not also mechanically fastened with a system designed by the manufacturer. Inconsistent adhesion of these unprimed substrates, specific design of the window, and movement due to thermal expansion and flexing, may cause application failure. It is strongly recommended that the customer contact the window/port light/hatch manufacturer for recommendations on proper sealing procedures.
- When using 3M Marine Adhesive/Sealant 5200 with metals, it may be necessary to prime the surface to achieve adequate adhesion and durability of the bond. Scotch-WeldTM Structural Adhesive Primer EC- 1945 B/A may be used for priming of most metals."
