How to replace cut out interior cabin walls?
I recently acquired a Grampian 26 that, after spending 7 years on jack stands, needs a lot of attention, including correction of some questionable prior "repairs."
The cabin interior was built with walls and a ceiling of fiberglass covered in gel coat. The prior owner cut out all of the interior fiberglass and gel coat, from the edge of the ceiling down to where the fiberglassed dinette or galley counter meet the wall. Where the interior fiberglass has been cut out, the backside of the exterior fiberglass is exposed. There is also a rough edge along where the cuts were made, and a gap between the interior and exterior glass layers along the edge of the cut.
The removed fiberglass is not a flat panel, but has two bends. Fiberglass was similarly cut out of the head wall, hang-up stowage across from the head, and the v-berth. The pic attached was taken prior to some repairs we've already made but will give a sense of the issue. The stripes in the cut out area are untreated pine battens that were attached with liquid nails but that I should be able to remove.
I'm hesitant to try redoing the fiberglass both because because the time required to make it look good would prevent it from being done in time to sail this year and because I'm not sure I have the skill to make it look good in any event.
So I'm hoping folks here will have some alternative suggestions as to what I can do.
I have searched through the archives but older posts were about recovering the walls, not replacing walls that had been ripped out.
Thanks very much for your help!
