Kenyon pressurized alcohol stove
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
MKirk51 - great idea about submerging the stove to check for leaks! I'll give that a shot.
I keep hearing how dangerous these things are but other than the possible flare up when trying to ignite the stove, what other problems are there?
While surfing around to check prices on the little butane stoves I came across this: http://www.cabelas.com/cabelas/en/t...box.jsp.form23&Go.x=28&_dyncharset=ISO-8859-1
For the price it can't be beat but I checked the manual for the manufacturers web site and it is strictly for outdoor use. Not to hijack my own thread but why are some propane stoves/ovens okay to use indoors and others aren't????
Manny
Nov 8, 2007
1,618
Gas stove dangers
Propane, butane, and other gases are heavier than air. If they leak, they will fill your cabin where they can suffocate sleepers, or blow up and burn down the boat.
So a safe inside installation has safety cut-off switches, sensors for the gas, and storage outside the hull/cabin with drainage outside the boat.
If you can pressurize the alchohol tank on your stove, you can find a leak by looking/smelling for dripping alchohol. Or, the pressure will drop if the leak is above the alchohol in the tank.
If there is no leak, and the tank holds pressure, then I'd give a try at lighting it. Absent visible signs of serious corrosion, it may well light. If not, you can release the tank pressure, then dissemble and clean the burner assembly.
I think the dangers of the alchohol stoves are overrated by some. The two danger points I have seen are burning of a little puddle of alchohol below the burner to heat up the vaporizing mixer when a flammable curtain or towel over the burner could catch fire, or losing the flame on a burner leading to a cloud of alchohol vapor that somehow gets ignited. But alchohol will dissipate, rather than pooling, and does not have the explosive energy of a gas fuel.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
The pressurized alcohol stove is really not any more dangerous than propane or butane, but they are such a pain in the butt to use and the flare ups are disconcerting. Propane can gather in a bilge, but I have never heard of an explosion so related. Most of us turn off our tanks when not in use, thus making the possibility of build up extremely remote.
The Origo will cook anything a pressurized stove will cook with a lot less hassle. There is no pumping, no burning off a cup full of alcohol, just light it and cook. You don't have to take the Origo off the boat to learn how to use it. Light it and cook. Very simple.
Beneteau 323 Annapolis MD
I would think the hard part would be expecting guest crew to use the stove. You know, like "first one up makes the coffee"?
Stove instructions
If they can't figure that out, what are they doin' on your boat? :eek: (joke)
higgs
Aug 24, 2005
3,738
Stu - if the stove is so complicated one needs training to use it - what is it doing aboard?
Manny
Oct 5, 2006
983
hmmm...
The same could be said about a marine head :D
Manny
zeehag
Mar 26, 2009
3,198
first one up better be me--i am only one allowed in my galley, and i awaken early and my kat doesnt make coffee..LOL
Nov 4, 2007
10
S2 8.0B Perry Yacht Club
You can find a Kenyon 206 operating manual here.
Scroll down the stove manual link.
Bret O.
I've heard ya just can't train cats. Maybe you need a dog? ... I fix the coffee pot the night before, and use propane.
higgs
Aug 24, 2005
3,738
Stu: Heads Vs Stoves
When it comes to marine heads we really have no choice but to educate visitors about usage. When it comes to stoves there are certainly units a visitor can use with little training. At any rate, no one has to take their head ashore to test it out unlike what is being suggested for alcohol stoves. This is a common sense issue. I will take a stove that does not need to be shore tested and practiced.
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
FWIW... our Pearson 30 came with a Kenyon stove. I don't recall ever removing it for "testing." We used it for years and not once did I set the boat on fire. However, I did sometimes feel the urge to move the curtains out of the way as I was lighting it.
I was perfectly happy with it, but the skipper decided it needed to be replaced with an Origo. I think he was getting tired of the whole lighting process.
I've heard that the pressurized stoves use less fuel than the non-pressurized Origo, but I never really kept track.
Once we got the Origo, I eventually made a deal with an Internet friend who was rehabbing a boat to sell and needed a stove. We met in the parking lot of the NH liquor store -- he got the Kenyon, I got some Pussers and Mount Gay, and everyone left happy. :)
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
1st of all - Call Kenyon and ask them for advice. They are very helpful.
2nd - pump up the stove and look for leaks. No leaks? proceed to
3rd - Allow a small amount of fuel into the depression below the burner and light it. Let this burn off completely. This is the pre- heating step - the most important part. Then open the valve and light the burner.
I have used this kind of stove for 40 years and never had a problem. You have to follow the procedure or it will flare up. The pre-heating is the key to no flare ups. There is no reason to remove the stove from the boat to try it. If the stove does flare up just - turn the valve off and the flame will burn out in a second. Then open the valve and relight. There is no need to be afraid of this. You will be in control of the situation if you follow the directions. As for complicated - I just re-read the directions - all 4 of them. So, its not too complicated.
The only reason everyone is afraid of this stove is they probably did not learn to use it correctly.
You can also use the stove to heat the cabin on cold days. Alcohol does not give off carbon monoxide. It produces carbon dioxide - same as we exhale on every breath.
As for the other fuels, propane is only usable if you have an outside storage locker. There are documented cases of boat explosions due to propane in the bilge. A leaking hose from the outside locker could have the same effect. Butane is alittle safer but still pressurized in a can and the seal between the can and stove can leak and the can can rust through.
higgs
Aug 24, 2005
3,738
Using an Origo - compare to last post
1. Remove rubber seal over pot
2. Use a long necked lighter to ignite canister
3. Cook
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I'd point out that a very large number of boat-related fires were due to pressurized alcohol stoves, as pointed out in BoatUS's book Seaworthy, and as the use of pressurized alcohol stoves has gone down, so has the number of fires.
A couple of points about alcohol as a fuel...
First, the flames from alcohol fires can be very difficult to see, as they often burn a very light blue or nearly clear. This is especially the case in daylight. This can make it hard to tell if there is a fire or not... until you get close enough to feel the heat.
Second, alcohol fumes are heavier than air, and as such can collect in the bilge.
Third, alcohol fires can be spread by water, and water is NOT a good medium to use to put out an alcohol fire for this reason. Alcohol can burn fairly well down to about 40% alcohol by volume... if you don't believe me, try lighting some whiskey or brandy on fire some time.
Personally, I wouldn't recommend using a pressurized alcohol stove on a boat. The Origo-type non-pressurized stoves are far safer...if a bit more primitive.
Manny
Oct 5, 2006
983
An update - I started poking around the stove and found that the pump seal was definitely past end of life, the pump handle was pretty corroded, and the vent/fill cap was also suspect. After checking the prices on those items and also wondering about the condition of the burners I ended up ordering a single burner butane stove for very little $$$. There were quite a few models with some starting at $10 but I ended up getting a UL listed one with stainless steel instead of paint for $35. I tested it out at home and was pretty impressed with how well it works. After about an hour of use between the medium and high settings there still is butane in the can. When the budget allows it i'd like to invest in a nice propane stove (and possibly oven) but for now the little butane stove should be more than adequate.
Thanks for all the input.
Manny
Nov 14, 2009
5
Hunter H26 Lake Michigan
Re: Bob M
I got by with pressurized alcohol stoves for many years thinking they were just fine. Once i ran into an Origo stove my perspective on this subject was forever altered.
Which Origo stove is best? I have a new-to-me Hunter H26 that is stoveless, but has a big whole where the original had been.
Sam
Sam, they only make one kind of stove, choice is one burner or two. Other models include electric heat above the canisters. most likely not applicable to your size boat.
Pearson 26W Marblehead
for higgs
and some of us dont have any trouble Alcohol stoves are reliable All you have to do is know how to use it correctly 40 years no trouble on a pressurized stove read my other post on this thread
