S
SW Fla Guy
I recently purchased a 1984 22' Mac. I pulled the rudder to fix some dings and noted that it is of a hollow construction. Because of the age I am having trouble determining if this rudder is meant to float when not rigged to sail. There were several areas of peneration to the hollow core, but then there was what looked like a factory drilled hole toward the very tip, that obviously drains any contained water when pulled from the water.
Thanks in advance.
Thanks in advance.
