Chart plotter/Auto Pilot Heading Errors
Sailors,
I recently noticed error in my heading vector displayed on my C90W.
Below is what Raymarine had to say about it.
Question:
"How do you adjust the Heading vector? It seems to be off a bit. When I point the vessel to a distant mark and than compare where the heading vector shows on the chart they are off. The further away from the mark the greater the error (of course).
"Under the "Setup Compass" menu there is a "Adjust Heading", and "Linearize Heading", soft keys, but they are grayed out, why?
Raymarine response:
"Smart Heading Sensor heading calibration and alignment is performed via the Multifunction Display (MENU->COMPASS SETUP->LINEARIZE COMPASS & MENU->COMPASS SETUP->LINEARIZE COMPASS). These options will be desensitized (i.e. grayed out) should the MFD not be interfaced via SeaTalk to a Smart Heading Sensor. If an autopilot or instrument is supplying heading data to the MFD, then linearization and alignment is performed via the autopilot control head or instrument display respectively."
This answer is confusing.
"These options will be desensitized (i.e. grayed out) should the MFD not be interfaced via SeaTalk to a Smart Heading Sensor.
And then goes on to say,
"If an autopilot or instrument is supplying heading data to the MFD, then linearization and alignment is performed via the autopilot control head or instrument display respectively."
So what is it:
- grayed out because it is Not using the Auto pilot or other instrument.
- or grayed out because it is receiving heading info from the Auto pilot or other instrument.
My guess is that it is grayed out because it is getting the heading from the S1's fluxgate's compass.
When I did the compass heading alignment for my S1 initially I used the "Auto" function to get the heading from the C90W COG, but I guess there must have been some current, I tried to do it at flood tide with no true wind, but I'm guessing I need to tweak it some more.
Also, there may be local variation from the chart displayed that is not being accounted for, placing the chart incorrectly in respect to the vessels position and heading. This can be adjusted by (MENU->SYSTEM SETUP->VARIATION SOURCE), but only has East or West in deg. increments of 1 deg. for adjustment
What are others using MFD's and Auto Pilots interfaced together experiencing regards to heading errors?
Sailors,
Question:
Raymarine response:
So what is it:
