heh, heh. you are so in trouble now. you are hooked way worse than you know. sailing is almost like crack (so i hear). i have been a sailaholic for about six years now. bad thing is I dont want to quit. and what ever you do never ever race.
That's a good idea!I also keep a pair of hand held radios I used for skiing on board. It's is very difficult for anyone at the helm to hear what is being shouted from the bow. I wish I had a windless! You know the longer you have the boat the larger your wish list becomes.
Here's that picture again. It would be a lot easier if you had a separate shorter line to tie to the real anchor line and then used the winch.I remember reading a post about bringing the line back to a winch. At least you'd get 25' of chain upon deck before it reached the winch.
I was doing that that terrible morning. I'd get it partially in and loose it before I was able to hook the chain. I use the cleat inside the anchor locker. The best tool you have when things aren't going right is your head.Then you tie a short length of line to the chain hook, long enough to tie to one of your bow cleats. This line doesn't have to be 1/2 inch, I used about four feet of 3/8 line I had laying around. Raise the chain and use the hook and line as a chain stopper. Leave the line cleated to the bow cleat and just release it from the chain as you pull more in.
The trick for me is to not loosen the line holding the chain hook. I thought at first that was the way to go and use the hook and line to pull the chain. NOT. Just keep yankin' the chain until it's vertical. If you can't pull after that, it's either wait for the tide to rise or use the engine to pull the anchor out, or do this: http://c34.org/bbs/index.php/topic,5064.0.htmlI was doing that that terrible morning. I'd get it partially in and loose it before I was able to hook the chain.
One of the downsides of your "marina" hermit is that you can't see what others have done. Many of us get good ideas by looking at lots of other boats and working from what works for others. I recognize the limitations you have, but again I suggest you spend a day walking the docks at a full "nice" marina and take pictures and get ideas.I am going to build an I-beam out of 3/4" PVC with a roller on the front. I think I have to cut my bow pulpit to fit it in there.
The chain tore up the gel near the chock on the bow. but I have been repairing the deck all over.
I want a roller that will positively gear with the chain. Is there a name for a roller that is designed to accept chain, like the winch on a windless?
Back in the 1700-1800's they had a continuous line on the capstan they would attach the the anchor line with "nippers" to pull the anchor line up.
The older I get the more I realize that I have to work smarter, not harder, to get things done. Maybe I can use the line I need to rig to help me pick up the mooring solo for this purpose too. It will essentially be a line run aft near a winch with a clip on the far end to hook onto a pendant. If I can hook it onto chain it will work for that too.
You CAN buy just the chain gypsy in a size to fit your chain, but one-way? You can probably find a used one. Baconsails in Annapolis has them. Then you'd just need a stong enough axle for it to spin on. Otherwise, you'd want a chain stopper. Page 150 West catalog.Is there a name for a roller that is designed to accept chain, like the winch on a windless?
I think I will accomplish the 'one way' mechanism by putting a pawl and ratchet onthe shaft like a winch. So when I pull the chain across the bow roller that has the chain grabbing sprocket the chain won't pay back out.You CAN buy just the chain gypsy in a size to fit your chain, but one-way? You can probably find a used one. Baconsails in Annapolis has them. Then you'd just need a stong enough axle for it to spin on. Otherwise, you'd want a chain stopper. Page 150 West catalog.
