I think for coastal cruising a DSC radio hooked up to a gps is the way to go instead of an epirb.
Doing the coast is more dangerous in the norther Gulf than out past the contenental shelf (deep water but a long way away from shore). Reason is Rigs, lack of other boats/ships around that can be of help, floating logs coming from the rivers and so on. You had talked about going to Florida. From CC you need to get out into the deep water and follow near the shipping lanes for that. Good news for you is that it's a near straight shot to Florida from where you are at, but from here we have to go SE first.$200 is pretty cheap. I was jsut talking about going along the coast, I don't want to do any open ocean cruising. at $200 that's hard to beat though.
ummm...nope. Best thing for coastal cruising is the personal epirb for about $200. It can be carried with you so if the boat sinks, it still transmits and it has unlimited range and the signal goes directly to the coast guard. You can also take it on other boats.
The cheapest 406 MHz personal EPIRB I can find is $335 and that is out of stock (nearly $400 elsewhere). I have read a bunch of bad things about the cheaper Spot PLB's, however, since a boat has a pretty good line of sight to a satellite they probably work better than for a hiker. I found them for under $100...of course its $100/year for a subscription.
http://www.gpsmagazine.com/comments/000419.php
Are you suggesting that I don't coastal hop, and just cut straight through the gulf to Fla.?Doing the coast is more dangerous in the norther Gulf than out past the contenental shelf (deep water but a long way away from shore). Reason is Rigs, lack of other boats/ships around that can be of help, floating logs coming from the rivers and so on. You had talked about going to Florida. From CC you need to get out into the deep water and follow near the shipping lanes for that. Good news for you is that it's a near straight shot to Florida from where you are at, but from here we have to go SE first.
make sure you have ports to duck into during the t storms that come up on ye during the summer months thru end of hurrycame season....they are not fun and make some fierce sailing....i, personally, like the farther out in the gulf seas--they are not as big as those near coast---we are currently in tampa bay watching a tboomer grow and hearing the noises resulting from them. if you look at the satellite weather on storm pulse and wunderground for the gulf every day you will be able to check which way you personally might prefer---the storms are nasty and pack winds to 60 kts inside them and rough up the seas very well...and the lightning kinda suxxxxxx.....good luck....the old 30 would be a solid boat to do it in--the newer ones arent as strong of hull...epirb negotiable--lifejackets mandatory....we have been doing passages farther out to sea than most do--i enjoy the distance from land myself--the water is nice and the surge less dramatic in a storm....file a float plan with friends and check in with them regularly and keep them posted as to exactly where you expect to be at what days----if you have the toy named spot--use it--is fun for your friends to be able to track you--it wont call for help for you but it will show where you are and path you travelled.....make sure you are able to sail in stiff breeze/high wind situations.......Are you suggesting that I don't coastal hop, and just cut straight through the gulf to Fla.?
Would you do that in an old catalina 30?
Yes you can. There are 3 pre-programmed responses you can send to people's cell phones and or email by a press of one button. The first message is a default "All OK". The second message is a pre-programmed message like "I need help like a tow" and the third message is a 911 type call that goes to the coast guard. Each message also sends corridinates and time. It covers most of the globe but not all of it like hight lats in Pacific....-it wont call for help for you ....
that is really good to know--is less costly than epirb and therefore more readily use able for those with low budgets--and friends and family can find ye!!Yes you can. There are 3 pre-programmed responses you can send to people's cell phones and or email by a press of one button. The first message is a default "All OK". The second message is a pre-programmed message like "I need help like a tow" and the third message is a 911 type call that goes to the coast guard. Each message also sends corridinates and time. It covers most of the globe but not all of it like hight lats in Pacific.
