Fin keel swap to shoal keel
3
2 31 Repentigny
I have Irwin 31 feet 1982. When the boat was sold new , Irwin offer two keels, fin and shoal keels. To reduce draft, instead to put lead bulb, I would like to replace the entire fin keel by a shoal keel with the same mounting keel bolt. Is-it a good idea ?? Any body tried to do this on Irwin or other sailboat ?
Thank you
Ross
Jun 15, 2004
14,693
How good is your moment of inertia and strength of materials engineering? There are probably other changes that Irwin made that don't get talked about in the literature.
Rick D
Jun 14, 2008
7,206
Can't possibly be worth the expense and commitment. The boat isn't worth the effort. Lots easier to sell it and buy a shoal keel boat if it is that critical. Don't mean to be curt, but a rational examination of the cost and effort vs. resale and expected time of ownership should reveal a disproportionate investment.
Dec 2, 1999
15,184
A better option may be to have the existing keel cut off to the proper (you determine) length and have a couple of half torpedos made by Mars Metals to bolt to your existing keel.
2,288
C30 Event Horizon Port Aransas
I'll do anything when it comes to modifying things, to the point where people think I am crazy. But I wouldn't try cutting off the keel to add some bulbs unless I was copying a job that someone already did on a boat like mine.
You can play around with some static moment equations and maybe get the righting moment clost but there is an aerodynamic factor to a keel that would be more difficult to get right. Unless you can put your hands on a boat like yours that it's been done to, you risk makning you boat not want to point well into the wind.
Ross
Jun 15, 2004
14,693
Hermit,
It's gotta be a hydrodynamic factor not aerodyanmic factor on a keel. ;)
RichH
Feb 14, 2005
4,773
Blueberry -
Mars Metal can provide you with a new shoal draft keel or provide you with bolt-on 'bulbs' that you can apply to a keel that has been shortened/cut down. They have the calcs. to keep the righting moments equal to the OEM design. This is not an inexpensive project. http://www.marskeel.com/
The most commonly used sailboat keel shape is an aerodynamic design: NACA010-xxxx which is an airfoil shape designed by NACA the predecessor of NASA
