Yanmar 2GM Fuel Leak
11
2 1985 H-31 Cambridge, MD
The rear exit port on the high pressure fuel pump of my Yanmar 2GM is leaking fuel. I can't get a wrench on the nut to tighten it without, it appears, removing the front port nut completely first. Is there any danger of doing further damage by removing that one?
Ross
Jun 15, 2004
14,693
Find a different wrench.
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
yep...like Ross said...buy one..bend one...make one...other options are crowsfoot wrenches...flare nut wrenches...ratcheting wrenches...and as a last resort...sticking the tongue out the right way...
Sep 8, 2009
1
Ericson 27 foot Sloop Seattle
I know it's been awhile since your post, but if you haven't got the right response, try getting a boxed end brake wrench. Those are the ones that look just like a boxed end wrench but have a notch in them so they can be put on the nut by going around the pressure line. You may have to bend the wrench to the proper angle.
Capt. Jim
Apr 23, 2009
11
Problem Solved
Jim,
Thanks for the productive response. In the meantime, I solved the problem. My yard mechanic told me there was no risk in removing the forward line from the pump to get at the one behind, which I did. After torquing the rear nut the best I could and re-assembling, no leaks!! BTW: the engine runs great.
Capt. Jim
H
halfhitchedbanshee
fuel line leak
Can u git a linewrench on to it ?
H
halfhitchedbanshee
If not no u should not have any problem if u remove it .
