For the past few weeks I've suspected our new motor has not been quite as perpendicular to the water line as it once was. It didn't occur to me until yesterday that the added weight of the new motor was bending the aluminum mounting post. Sunday, during an especially difficult entry into the slip, well...let's just say it took a bit of a knock and now it's REALLY bent. I suspect the post may be cracked under the locking mechanism. I took pictures, but didn't see a crack until I downloaded the pictures when I got home. It's not noticable to the eye while looking down on the post. Keep in mind that the motor mount had a slight decline (maybe 20 degrees or so) downward bend to it originally.
A rigger I know suggested removing it completely and putting in a whole new motor mount; one of those spring loaded things that let you lift the motor straight up and out of the water. He says it would be easier to lift than the motor tilt method I have now. I have to admit, the bending over and heaving it up gets difficult. The original mounting post goes through the hull and is secured to an L bracket that is mounted to the inside aft section of the port lazerette.
So here are my questions to this august and esteemed panel of experts here: 1) The boat is in the water, do I take the boat to the yard and try to rebend it back into shape and reweld the crack, then reinforce the post with an inner sleeve....or 2) do I remove the entire assembly and install a new motor mount? How is the new mount secured to the transom other than using through bolts and washers (the hull is not cored)? What is used as a backing plate? Can I use a large 3/4" thick plastic cutting board (which I already have)? How much is this going to set me back??
