Isn't there a way to get to the Atlantic after you go thru the C&D Canal without going down and around Cape May? I was trying to follow the charts on line and ran aground in Trenton.
Actually yes it will. The Cape May Canal runs from (West) Delaware Bay into Cape May Harbor from there you can run out to the (East) Atlantic Ocean. BTW you'll actually be facing South when you exit Cape May Inlet. There are 3 bridges in the canal, 2 fixed bridges each with a 55' limit at MHH Tide plus a railroad swing bridge which is normally open. Taking the canal, if you fit under the bridges, saves you a couple of hours versus running outside around the shoals. If you take the canal be cautious as they're dredging it. Also keep an eye on what's approaching from behind as the power boys fly through there. Although most everyone slows for the railroad bridge due to the narrow channel.Going through a canal west of Cape May won't put you in the Atlantic. The Atlantic is that big blue area east of Cape May and Cape Henlopen.
After responding to your post I realized your likely looking for a way to avoid running all the way down Delaware Bay. If that's the case the answer is no. Unfortunately you'll have to make the run south on Delaware Bay and then, depending on mast height, either take the Cape May Canal or run around the point into the Atlantic. From the C&D to Cape May Harbor via the Cape May Canal takes approximately 7 hrs at 7kts. Add more time if you need to run outside. Best to time the tides down Delaware Bay. Catch them and you can see speed over the ground in the 10kt range. Miss them and you'll feel like you're crawling. In most cases it's difficult to run the tide the entire way. Still good to make the effort though.Isn't there a way to get to the Atlantic after you go thru the C&D Canal without going down and around Cape May? I was trying to follow the charts on line and ran aground in Trenton.
Been through many times with the previous boat and they're both 55'. The charts also list them as such. Prior boat had a 50' stick and we always cleared w/o a problem.Not going to look it up, but I as I remember it, the two bridges are listed at 50'. Been a couple of years though since I came through there. I do know that I have a 55' mast, and I drug the antenna on both bridges, coming under at low tide.
So the OP implies he is heading north. Exactly how do your get from the C&D to the Atlantic without passing by Cape May?I think that it all depends on where on the Atlantic you plan to go. You can certainly get to the ocean from the C&D canal without going near Cape May. If you wish to sail up the Jersey coast then Cape May enters your plans.
A look at the charts shows that rounding Cape May is not needed to enter the Atlantic, passing Cape May and Cape Henlopen are the only ways to leave Delaware Bay but you may not see either of them on your way out.So the OP implies he is heading north. Exactly how do your get from the C&D to the Atlantic without passing by Cape May?
I won't argue this point. I have better things to do.A look at the charts shows that rounding Cape May is not needed to enter the Atlantic, passing Cape May and Cape Henlopen are the only ways to leave Delaware Bay but you may not see either of them on your way out.
Edit to add : Check my first post.
