Location H20 Balast
1
HUNTER 26FT WATER BALAST LAVALLETTE NJ
Iam Trying To Locate Where The Water Balast Tanks Are In A 26 Ft Hunter With A Swing Keel. Would Like To Put In A Thro The Hull Depth Finder. Do Not Want To Disturb The Balast Tanks. Any Suggestions?
Hunter 26 Illinois
Here's a picture
In this picture you can see the tank and in front of the one man you can see the place under the step for filling the tank. Usually the throuh hole is put under one of the access holes under the stern bed. Mine is in next to the bilge pump.
Z
ZEE326@AOL.COM
in This Picture You Can See The Tank And In Front Of The One Man You Can See The Place Under The Step For Filling The Tank. Usually The Throuh Hole Is Put Under One Of The Access Holes Under The Stern Bed. Mine Is In Next To The Bilge Pump.
Thanks For The Photo Any Suggestions Where To In Stall A Thro Hull Depth Finder?
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
As John mentioned, if you pull off the aft sleeping mattress you will find an access board for the "bilge", what little the H260 has.
Check the owner's manual on your depth finder. Some are capable of getting readings right through the fiberglass hull. In that case you don't need a hole in your hull.
