Re-locating engine shutdown on H33.5
544
None None Rochester, NY
The engine shutdown knob on this model is located near the top of the stairs to the cabin. In order to shut the engine off, you must get down on your hands and knees, reach down, and pull the knob up. Most inconvenient.
Has anybody relocated the shutoff cable to a better spot? If so, where did you re-locate it? Thanks...
Jul 8, 2004
155
Hunter 33.5 Portsmouth VA
Cockpit Location
What year is your H33.5? On my 1988 model, the shutoff is located with the "B" panel on the starboard side of the "T". It's within easy reach of the helm.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
The reason the shut-off is located inside the cabin is simple security. With the cable shut-off in the cockpit anyone can start the engine without getting access to the cabin. If you have a Yanmar engine you probably already know that the start key is the same for ALL Yanmars. At least having the shut-off below requires additional entry to start the engine.
Jul 8, 2004
155
Safety Trumps Security
IMHO safety should trump security. I would want the shutoff where the operator can get to it quickly. Preventing someone from just starting your boat can be thwarted by simply turning the battery switch to OFF when you leave the boat or by other installed mechanical means.
Besides, if someone really wants to start your boat, a shutoff installed inside the cabin isn't much of an obstacle, key or no key.
7,752
Alden 50 Sarasota, Florida
Before this gets too far into a security debate Ken, take a look at how the stop cable is routed currently to see if, with a longer one, you can route it to someplace you consider preferable. The cable itself is nothing unique so it all depends on how well you can snake it through the boat in gentle curves without kinking it.
My dock neighbor's boat (exact same Yanmar as mine) has a completely different ignition lock key. Regardless, I'm not too sure what the statistics are on #'s of boats stolen while at the dock but the stop cable isn't much of an obstacle.
Dec 3, 2003
544
Thanks Guys
The shut-off pull knob does not prevent the engine from being started (unless it is left pulled out). I have never heard of this location being a way to prevent anybody from starting your engine.
Yes, I have to look at a suitable location and see if I can make one work through the curves it may have to go through.
Thanks.
Dec 3, 2003
544
My boat is a 1990 model. I don't know what you mean by "B" panel and "side of the "T".
Jul 8, 2004
155
Cryptic Description
Sorry for the cryptic description; blame it on 40+ years of technical/military associations.
Yanmar produced two Control/Warning panels early on. The "A" panel had idiot lights, buzzer, key switch, and start pushbutton. The "B" panel had different style lights, buzzer, key switch, start pushbutton and tachometer. See below.
The sole of my 33.5 cockpit is "T" shaped. The base of the T is forward and leads into the companionway. The top and arms of the T provide room for the wheel.
544
I wonder why they changed the design
:doh:Thanks cbsailor for the information. It all makes sense now.
