It plugs into a cigarette lighter and gives you the voltage of your battery. Best part about it besides the simplicity is the cost, $15.
Could you give a link or brand name to the tester? I think it would be a quick and easy way to aid in troubleshooting.It plugs into a cigarette lighter and gives you the voltage of your battery. Best part about it besides the simplicity is the cost, $15.
Agreed. Myself, I would crack open the cheapie to get rid of the cig lighter plug, and solder on some leads so that it could be connected directly to the boat's DC panel, and I'd tweak any calibration to make the cheapie agree with a known good meter.I purchased a similar item from Wally World a couple of years ago. I compared its voltage readings against measurements taken on the 12V bus at my breaker panel. Although my Fluke digital meter hadn't been calibrated recently, the disparity between the voltage readings was significant. Just moving the tester around in the cigarette lighter socket could get readings 1+VDC different from the Fluke.
Well, sure, but on a 25 ft boat with just one or two batteries, I'd give one of those cheapies a try, after doing the above mods. A better idea would be to buy a halfway decent digital multimeter (DMM) on sale, and provide test points on your panel so that you could easily monitor the batteries with the DMM.Battery condition (voltage) and current draw are critical to cruisers with lots of money invested in large house banks. IMHO these low cost voltage testers are no substitute for battery or bus direct connected quality volt and amp meters.
