Shorter turbuckles
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
It is probably less money than you think and required maintenance to change the rigging. If you are convinced there is no problem with the deck core (you have tapped around the mast step haven't you?) and that this is the solution, I don't understand why trimming the existing studs a quarter inch each and running a die on them won't work.
BobM
Jun 10, 2004
3,269
Mechanical fittings at the base is a good half measure if your wire is good. Most failures occur at the bottom. They are easy to install.
BobM
Jun 10, 2004
3,269
Close body turnbuckles
Ronstan has a closed body barrel that might be shorter and allow you to pull the rigging tight before runnng out of thread.
Avoid them like the plague or be sure to use Tef gel. Closed body turnbuckles, especially if stainless and not plated bronze, gall like nobodies business.
Mougly
Jul 14, 2009
59
Sonic Sonic 23 Barrie Marina
I am not sure what those are, can you post a link please?
