Can't see from the pic if you have a center support , but all you need to do is tie to the bow pulpit and the stern rail (I use a pool noodle over the rail to insulate it), make a support out of wood that bolts into the mast tabernacle that has a vee in the top to rest the mast in, make a cutout in the base of the vee to accommodate the rigging. Bungee cords are strong enough to hold it on, though I made an aluminum bracket at the bow for the mast to bolt to on mine. Loosely tie all the rigging, the only standing rigging that is disconnected is the forestay. Boom and mainsail go in the cabin. Motor goes in the back of the truck while on the road. When you get down this way, you can check out Frank's boat, v25, and mine, v22-2 for ideas.
