window repair
S
sbatts
We have a 1987 , 33ft. Irwin. We need to replace the cabin windows (fixed). There is an aluminun frame secured with rivets. How do we remove the frame to replace the window pane?
Thank you
sbatts1@gmail.com
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
The rivet heads have to be remove by drilling, grinding, or cutting with a coal chisel. I wish I knew os an easier way but I don't. Maybe someone else is smarter.
Good luck.
Joe S
Susan
Apr 8, 2009
2
Irwin 33 Madisonville, LA
Thank you Joe. I wish there were an easier way also. After drilling those out, the metal frame-work is replaced with new material or rivets replaced in the same framework?
Thanks,
Susan
Jun 13, 2005
559
I think that if the original frame is good that you could reuse it. I don't think that I would use rivets however. I believe I would use machine screws with nuts on the inside. You could fasten them through a cut rubber gasket or a gasket made of caulking. That way , after it is set up in place and cleaned up you can tighten the seal a little more.
Good luck.
Joe S
Feb 23, 2009
17
2 Citation 34 Fredericton, NB, CAN
replacing non-opening ports
Thank you
sbatts1@gmail.com
We left the frames in, cleaned them up and the result was grand.
Take a look at
http://irwincitation34.wikispaces.com/Replacing+non+openong+ports
Rik and Linda
Mystery
Irwin Citation 34
trip blog at: http://www.sailblogs.com/member/ic34_mystery/
Jun 13, 2005
559
Rik and Linda, Thats a nice looking job. Congratulations and thanks for the post.
Joe S
Jun 4, 2009
2
2 37 center cockpit mark III Port Clinton
Are there screws on the outside of the window that hold the plexiglass in? When we replaced ours we simply took the screws out. the aluminum frame on the inside was not affected. I suppose yours are totally different (our boat is older).
Feb 23, 2009
17
Yes - ours are screwed right through the Lexan.
Rik
