Lee helm
vines
Nov 19, 2008
29
Hunter 212 Lake Ray Hubbard
My Hunter 212 has terrible lee helm in light air. All the books say to move the center of effort back but nothing we do seems to help. I steer into the wind to try to keep her on course, but all that does is put on the brakes. Any ideas?
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
Try easing the jib. I have found on my 216 in extremely light air the jib will pull the bow off the wind until I am on a reach easing the jib lets me get back on course. The problem is that you don't have enough speed for the keel and rudder to be effective.
vines
Nov 19, 2008
29
I totally released the jib without any affect on the lee helm. I steered off the wind in an effort to reach and the boat just kept going off the wind by itself until I was on a broad reach. It wanted to run like it was afraid of the wind. You're correct, the low speed also affected my ability to steer. I've had that problem with other boats but not the lee helm problem. Still puzzled...
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
For very light air, try these techniques:
Place your self and crew on the leeward side. This will keep the boom and sails away from the breeze and help them keep their shape.
If you can, adjust the sail to be flatter (if the wind is VERY light). Too much draft can create more drag than lift.
Make sure the board is all the way down.
G'Luck!
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Have you tried increasing the mast rake? Raking the mast will move the CE back which will increase weather helm and decrease or remove lee helm.
vines
Nov 19, 2008
29
Thanks for the suggestions. I can't affect the mast rake because I don't have a rear stay and the front stay is not adjustable. Tightening the outhaul really only puts a pucker along the boom. It doesn't really seem to affect the belly of the main very much. Neither does the vang. I don't have a traveller. The swing keel is definitely all the way down when I have the lee helm. It could be my main is the problem. If you noticed the 'my battens curve backwards' thread you will see I am having trouble with it.
Clark
Jun 30, 2004
886
Oh, I didn't make the connection. If your batten(s) are messed up, you'll have practically no power from the main (in very light air) and that could cause the lee helm. get that fixed and try the other tips . . . you should be fine.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Vines, your rear stay (or lack of one) has no affect on mast rake. If your headstay is not adjustable you could put a turnbuckle on it or at the very least you could add stainless steel tangs or a highfield lever. In any event it would pay you to at least measure the amount of rake you currently have.
J
jackasch
Rudder?
Has anyone replaced the stock rudder? This can drastically change things.
vines
Nov 19, 2008
29
Replace the stock rudder on a Hunter 212? Is it longer, wider, thicker, or shorter, thinner, skinnier?
J
jackasch
rudder
I've got a bigger boat, and replaced my rudder. the new rudder had too much forward of the rudder post. This created very pronouced lee helm, to the point of being very exciting when getting hit with a gust.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Re: rudder
Is your rudder too far "down" (forward). I'm not familiar with an H212, but this can make my H26 have excessive lee helm. BrianW
