Seacocks
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
What is the best practice with seacocks, open or closed when leaving the boat for a number of days?
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
We need more information to answer your question.
Do you want to keep the boat or would you rather have the insurance money?
Raising the boat and paying for the environmental clean up could well use up more than the insurance money so you might want to close the sea cocks in either case.
Dec 17, 2008
9
Sabre 30 Mark III Friendship
Except, of course, the cockpit drain seacocks (if applicable). Don't want the cockpit to be a puddle.
Nov 22, 2008
3,562
Which is why cockpit drains should exit above the waterline. They don't on a lot of boats but that's one of many common design defects.
I modified the long drains with seacocks on my boat to simple, straight through, drains that I can clear with a stick. I can see the water come almost up to the top when going fast under power or sailing hard but have never had water come back into the cockpit. If a wave does flood the cockpit, the shorter and straighter the run of the drains, the faster it will empty.
2,288
C30 Event Horizon Port Aransas
I am waiting unitl I get insurance before I leave mine open when I go home.
As Roger said you have to drain the oil out of the engine before leaving them open while you are away.
Jun 1, 2004
8,323
whahh?
Hmm.... that's a bit unclear to me, Hermit...
Nov 22, 2008
3,562
It's to avoid the oil slick and pollution fines when the boat sinks. Don't forget to empty the fuel tank as well, Hermit.
