Can your anchor be too big?
530
Catalina 22 Kemah,Texas
So, I got my anchor deployed, then couldn't pull it up. I did not "set" the anchor since it was not windy and I was on deck keeping an eye on it.I ended up breaking it out after about 20 runs and an hour of frustration. I ended up bending it. so now I want a bigger better anchor and am wondering if I had this much trouble with this one is a bigger one going to be lost on the bottom? My little six horse doesn't have much uumph for breaking out an anchor.
I have already donated one anchor to the deep, so I am reluctant to use high dollar gear all the time in a lake.
boat: catalina 22 sw keel
6 horse outboard 2 cycle runs great
anchor super hooker danforth type 10 lbs.
12 ft water 50 ft rode out aprox 4 to 1 scope
10 ft 1/4 chain 150 1/2 three strand nylon
Ross
Jun 15, 2004
14,693
Pull yourself up to a 1:1 scope and then break out the hook. Unless it is fouled it will breakout with no problems. If you bent the anchor you were probably fouled on something on the bottom such as a log or some abandoned equipment. A ten pound Danforth should be enough for your boat except in a severe storm then maybe fifteen pounds.
Mar 8, 2009
530
breakout
I usually try to anchor in mud but sometimes I cant tell what the bottom is.
I have to get a running start to breakout the anchor.
Dec 2, 1999
15,184
It was probably fouled on something. This happened to use several years ago. It ended up being a cable. I ended up cutting the anchor line and that was the end of that anchor.
Jun 5, 2004
209
- - Eugene, OR
Similar thing happened to me a few years after I started sailing. We were on a local reservoir on the hook for the night. In the morning, after breakfast, we tried to pull up the anchor. We got the anchor rode vertical, but no further. Luckily, we were in relatively shallow, warm water. I grabbed a mask and snorkle and dove down 15' - 20' to see what the problem was. Our anchor was hooked into the roots of a tree stump. Easily cleared while I was down, but I'm glad it wasn't deeper.
Jim Kolstoe, h23 Kara's Boo
Sep 19, 2006
643
SCHOCK santana27' lake pleasant,az
probably the wrong type of anchor for lake use. too many trees down there ,I have this problem more often then not ,haven't lost it yet but a good winching can bring up a pretty good sized tree or rock.
try a mushroom anchor good for mud and cheap so if it fouls no big deal
Ross
Jun 15, 2004
14,693
A trip line on the anchor would allow you to pull it out backwards.l
Bob J.
Apr 14, 2009
775
Sabre 28 NH
If you get a fish finder you'll be able to distinguish the bottom type by the return echo.
I'd be careful getting a running start to breakout the anchor. Sooner or later you're going to break something & it always happens at the worst possible moment....
Bob
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
A 10 lb anchor that is not fouled will come off the bottom without power. Since this has happened to you on several occasions, it sounds like your bottom conditions are subject to fouling. I Agree with Ross, add a trip line. Pull the anchor backwards to clear it.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
Oh boy! You had to be hooked on something. There is no way you should not have been able to break out that anchor if it wasn't.
To answer your question, a bigger anchor would be better but on your boat in a lake with 12' of water you shouldn't go too big or you'll be breainng your back.
Now as to your stuck anchor in only 12' of water. What you could have done is is form a loop of chain or weighted line around your anchor rode and with your rode snug and a line on your weighted loop or chain, slide the loop down the rode and over the shank of the anchor. Then, If you have a dinghy, or with your main boat if you don't have a dinghy, slack your rode off and pull on the loop in the opposite direction you set the anchor in, and it should back right out.
Have fun
Joe S
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Ross is dead right. I NEVER wrestle with an anchor!!! Simply pull your vessel forward till the anchor rode is vertical and snub it off immediately. Then just sit & wait a few minutes. As the line comes loose take up the slack again and snub it. This procedure will break out your anchor every time with no muss or fuss or swearin' Let the wave action do the work of breakout while you sit and monitor it, it's that easy.
zeehag
Mar 26, 2009
3,198
please listen to ross and alan----i call it overdriving the anchor--but is actually running up on it and pulling up tight until the boat and water loosen it from the teeth of the mud--i have an ericson 35mII and a 30 pound cqr--i drive up to it, pull tight to straight 1:1 scope and wait for a bit--then it comes up easily--i do not have a windlass, and i have 100 ft of 5/16 chain--and i am female.....donot need horsepower--just need patience .....goooodluck....~~~~~~~_/)~~~~~~~
