I've briefly reviewed their literature.
State of health information is simply not available from available common monitoring methods such as voltmeters or current counting meters.
That's simply not true. We have had detailed discussions here about the algorithms of the Link series battery monitors. Battery health has a lot to do with the healthy complete recharging of batteries. This unit seems to be designed to tell you when it's failing and little to tell you what condition they're in as
state of charge.and amp hours (really KwHr). After all these years, one would think that a digital readout could provide actual numbers and not another analog "meter."
The BB-DCM must be installed directly to the battery terminals, and failure to do so will cause the BB-DCM to operate incorrectly. If the battery is located in an inconvenient location, audible alarms will inform you that further investigation is necessary.
The location requirement for this unit makes it highly impractical for sailboats. We have what I consider one of the best battery box locations on ANY sailboat I've EVER seen, and it's right in the saloon, forward of the galley. The C30s and C36s do, too. But I'd much rather look at my Link 2000 instrument right there in my nav station than have to pick up the saloon cushion and the battery box cover to look at this little puppy.
Since "it doesn't need a shunt" it is NOT measuring amperage draw or input, and thus is worthless in terms of battery charge state or condition in terms of what I've used (say, daily) or what I've replenished (i.e., alternator or other charging source). It also doesn't tell me what my instantaneous or averaged period amp draw is, so I can't tell if I inadvertently left something on.
If their claims of these issues are correct, I would consider one only in combination with the coulomb reading meters (i.e., Links-series) they so blithely trash in their website:
- How full is the battery?
- How much energy is available now?
- How much energy could the battery hold now if fully charged?
- How much storage capability has been lost since the battery was new?
- How much battery life remains?
- When to recharge the battery?
- When to replace the battery?
They claim the Links need to be reset and don't work in the range most of us use our battery banks. Hogwash! We've figured out the algorithms and Rich Stidger has penned the quintessential "Gothca" explanation for how to adjust Links properly so they work. See:
http://c34.org/bbs/index.php/topic,4922.0.html (Thanks again, Rich!) These instructions work for Links 10, 20, 1000, 2000 and the Link Lites and Pros.
I've learned a lot about the proper care and feeding of batteries from reading, experience, this website and others. This simple little thingie doesn't answer half of the questions skippers need to know about their electrical systems, and could create more indifference to battery care on the part of un-knowledgeable skippers who would use and depend on it.
It does look like a handy tool for fleet managers who care little about daily battery use and recharge levels, and who could use it to schedule battery replacement programs and identify prematurely bad batteries
Thanks for bringing it up. How'd you find it?
