I have a 1980 25 ft Oday, and the wiring from hull is to short to conect to the mast wiring, how do I replace with new as I cannot find where wires from accessory panel travel to bottom of mast area. Any ideas would help even if a short cut. thanks
Denny,
I would measure from the wire on top of the cabin to a bolt or anything that I could use for a reference point inside the cabin. If you have a fabric head liner inside, the wire is probably under the fabric. If the four bolts to the mast are visible inside the cabin, that wire has to be right in that vicinity. You may have to take something apart to get at it. I ran into the same problem that you did years ago and I ran a new wire. I did this because I added a steaming light to my mast and I needed one more wire which I didn't have. Now that I removed my steaming light, I think that I'm going to remove the wires that I added, and extend on to my old wiring in the same way that you want to do.
