Hi Joe - I had not noticed the weld marks when I enlarged your thumbnail. Seems like a good way to keep it dry. As I understand it, the LE was the same boat as your friend's with wheel steering (loose) and a furler added. I like the furler for single handing but the wheel I could do just as well without.
The Limited Edition had the steering wheel and the inboard diesel engine. My friend's 272 has a tiller and bracket on the stern for the outboard. I'm not sure about the HP of the outboard, but it was either a Yamaha 10 or 15 HP 4 stroke. I think that his boat was a little lighter by about 500 Lbs in the stern with the absence of the wheel and inboard engine. We pulled into a place called Hadley's Harbor in the Elizabeth Islands for the night and I slept in the Port settee in the normal way with my feet facing the stern. That night I had to turn completely around the other way. The acids in my stomach were going into my esophagus because my feet were higher than the rest of my body. In other words, the stern sits higher than the mid section of the boat. I didn't get much sleep that night. The only other thing that I didn't like about the 272 is the mass of halyards and control lines that come over the top of the cabin on both sides of the companionway. Having the main sheet, topping lift, two sets of reefing lines and both halyards set up that way along with all those clutches, just isn't my cup of tea. I'm sure that these are great features and I'm really not knocking them, but it's not something that appeals to me in a sailboat. I like to keep it simple. My idea of single handing a boat that size is to have an autopilot, a good roller reefing furler, and Gennie winches within reach. I like my halyards at the mast and not led into the cockpit. I guess being a "Geezer", I'm kind of set in my ways.
