ODay 25: Has anyone re-rigged the keel pennant to the cockpit instead of hoisting up at the table pedestal? Is it true electric plastic conduit, well glued, is the way to go? If so how is a waterproof connection made at the pennant's entrance point into the boat?
I remember reading about someone on this forum who re-routed his centerboard pendant line to the cockpit via single sheaves and having it accessible from the cockpit. He also showed pictures of it. I had talked with Rudy of D & R Marine about the need for a wire cable on the 1975 O'Day 25, and he told me that braid line can be used in place of it. The centerboard on your boat is made of fiberglass and probably weighs about 60 lbs. I'm not certain on how the wire is connected at the centerboard. It may enter a small hole in the trailing edge of the board, and terminate with a crimped on cap in a 1" diameter hole near that edge. Some of the O'Day keel centerboards have a small sheave up inside the keel slot for the pendant line to go through and some don't. My O'Day 222 has this sheave but I'm not sure if your boat has one. The only way to really find out is to be able to look at it out of the water with the board down. My 222 has a piece of pipe that goes into the cockpit via a rubber hose for the pendant line. I think that this guy may have used cheek blocks on the side of the settee births, and led the line into the cockpit somehow. Perhaps he'll reply to your thread. Here is Rudy's site:
http://www.drmarine.com/ If I was going to do re-route a pendant line, I would use a combination of stainless steel pipe and rubber hose if possible. Otherwise, I might opt for the cheek blocks. At any rate, I would use braid line in place of the wire cable. It's really hard for me to say without looking at it. One of our club members has a 1975 OD 25 keel/centerboard with the same type of set up as yours. It's been a while since I've been in his boat. Perhaps I'll get the opportunity to check his boat out again this season when I see him at the club. Good luck with that. For more info on that, call Rudy Nickerson. He may be able to tell you if it's doable. As for myself, I think that it is doable.
