Engine starting problems
J
JBorges
The Yanmar HM35F on my '89 Hunter 37 has been having intermitent starting problems. Meaning that when pushing the starter button, the engine does not turnover.
This season, I have 2 new batteries and a new starter switch which seemed to have solved the problem until last Saturday.
After motoring for 4 hours with the battery selector on "both", and then shutting off the engine it would not restart on 1, 2, or Both until I replugged into shore power.
Also, recently, after depleting my #2 battery overnight, it did not recharge while running the engine the next with the battery selector on Both. It did recharge after running the engine with the selector on "2".
I have heard that the problems could be: the battery cables are undersized, the alternator is not working, or I need a starter solenoid installed near the starter to bypass the undersized wiring that runs to the engine panel in the cockpit.
Any thoughts would be greatly appreciated. Thanks.
AXEL
Mar 12, 2008
359
Catalina C30 MKIII WEST ISLIP, NY
Re: Engine starting problems H37.
I have heard that it is not a good idea to try and charge your batteries with the selector switch on BOTH. Something about if one battery is weak is will suck the charge out of the stronger battery. Excuse my lack of technical verbiage, but I'm pretty sure there is fact to this. I'm sure someone will back me up on this.
Tim R.
May 27, 2004
3,626
Those are all valid possibilities but try the simple stuff first. This sounds like a possible bad ground to me. Double check all your connections.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
This sounds like a problem/solution I posted about some time ago. The issue may be the aging wiring harness and its inability to produce -- and deliver -- the needed voltage to the starter solenoid. This comes from impedence in the wires and all the connectors. It's worth checking and cleaning all of them. In my case, I added a fused 12vdc relay to the solenoid -- bingo. No problem since.
To read this item, go to Boat Info>Knowledge Base>Engines>Yanmar>Starting Problems on this site. There are 3 items posted there about this topic and its solution.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
Not an expert here but you say it works fine after hooking to shore power ? Seems maybe some thing is happening from the Selector switch and the batteries or some place in between.
Bee
It all depends on hwo it's wired
I agree with Tim, check your grounds. Also check the fuse and fuse holder between the start button or switch and the starter solenoid.
2,288
C30 Event Horizon Port Aransas
How does adding a relay to the solonoid help?
Is it the long run to the started button that you want to avoid?
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Common Yanmar problem. Warren has the solution. Here I'll reproduce some of the stuff I have on file.
Rick,
Don't swap starters. It's not the problem.
Sitting next to the starter are two molded connectors. The larger one has two larger pins in it. Spread the pins back apart. There is a similar connector about a foot off of the panel. Do the same there.
This is a normal problem with the older Yanmar panels and harnesses.
__________________
Pat McCartin
www.inlandmarinediesel.com
Guest
PostPosted: Fri Apr 22, 2005 7:41 pm Post subject: hard starting Reply with quote
The problem with aging Yanmars not engaging the starter is the wiring. Adding a relay to the starter solves the problem. You can use a continuous duty marine solenoid from West Marine or pick one up at NAPA for the purpose.
The solenoid should have four posts, two high amp, two low amp. On the low amp circuit, connect the starter key wire to one post, and ground the second post. Enaging the key will trip this circuit. On the high amp side, connect a #8 guage wire from the solenoid to the battey/alternator post on the starter motor. Then from the second high amp post run a #8 guage wire back to the post on the starter where the wire from the key originally came from.
Engaging the key will trip the low amp circuit which in turm engages the high amp connection which gives you a very healthy current to the starter solenoid.
Another thing you can do is add a remote start switch (for example near the engine) by connecting a second switch (make sure it is fused) beyween the battery side of the high amp circuit on the solenoid and the key side of the low amp circuit.
Back to top
mjs2
Guest
PostPosted: Thu May 26, 2005 12:05 pm Post subject: starter problem Reply with quote
I had the same problem--each time I heard a click from the starter, but it wouldn't start turning the motor. I had to hit the start button multiple times, and eventually it would start. Last year I bought a new starter and replaced it, but still had the same problem. Then I read some of the other posts that mentioned that the wires were not sufficiently thick to handle the current from the switch to the solenoid, and they recommended putting in a second solenoid. I found it hard to believe that this would work because the wire seems to be around 12 gauge already which you would think is sufficient, but I figured I'd try it and I purchased a solenoid model COLE HERSEE 24117-01-BP 201337 from west marine, and installed it yesterday. I used thick cables 4 gauge from the battery switch to the solenoid, and 10 gauge from the solenoid to the starter (although you may want to go to 4 gauge for both). Then tested it 4 times-- each time the engine started on the first try. So this fixed my problem.
Back to top
Sorry to continue this thread on the Yanmar starting problem, but I'm 12 volt challenged as well, and a bit confused on how to rewire the problem away.
My 1988 IP31 has the 3GM30F engine, and I've had this oft-described starting problem for most of this boats life. I'm in agreement that the under spec'd wiring harness is the problem, and I would throw in the cheap 30 amp fuse holder, that appears to be 16 gauge wire between the 10 or 12 gauge wiring running from the key switch to the starter solenoid. I bought the Cole Hersee #24117 solenoid, and after tracing my wiring from starter button, key switch, alternator and starter solenoid, and then reviewing the wiring setup from "dgrosz" (4/23/05), and "mjs2" (5/26/05), I'm still confused.
"mjs2" is running a wire from the "battery switch" (?) to the solenoid. I assume he meant the starter key switch. "dgrosz" describes grounding the CH solenoid on one low post, then connect the other low post to the starter key (assume at the red wire post). Then from the CH high post, run a wire to the starter solenoid post where the current red fused wire and battery cable terminal are attached. That would replace the red wire running up to the starter solenoid, via the questionable wiring harness and fuse connector. He then connects the other high post on the CH solenoid to the alternator battery ("BAT") terminal. I see were this takes the red wire and its fuse from the wiring harness out of the mix. I also assume that the existing starter solenoid mounted on the starter stays in place. Neither really states that. I assume the CH solenoid and heavier wire (I'll use 8 gauge) is doing nothing more than to get away from the wiring harness (at least the red wire key-to-starter solenoid part of it). If I'm correct up to this point, it would appear to me that I need to remove the red wire running from the alternator/BAT terminal to the battery power terminal on the existing starter solenoid. Do I have this right ? Are there different wiring harnesses by boat manufacturer ? (Note, a 1987 Cal 33 in my boat yard has same engine and wiring harness, and the same problem) If I'm wrong, can someone describe the setup simply for a boat with the Yanmar panel with a starter button and key switch ? Up here in RI, I will not be firing up the engine for another couple of weeks, and would like to avoid blowing out something.
Starter switch wiring...
This seems to be a common problem on Yanmars. I have it from time-to-time on my 4 cylinder 4JH-TE. I have done a whole bunch of research on it, and the general consensus is that the problem is caused by the wiring to the starter solenoid.
Yanmar starter solenoids have two windings, a high current coil that pulls the solenoid in (and then is turned off), and a lower current "holding" coil that holds the plunger in place. The result is a brief high current spike that happens as you push the starter button.
If the wiring to the starter button is too long, too smaller gage, or the starter switch has developed some contact resistance, the added resistance will not allow sufficient current through the solenoid to pull-in adequately during the initial current spike (Ohm's Law).
The general consensus (which I have not yet adopted) is to install an automotive type relay close to the engine, and use heavier gage wire from the battery, through the relay contacts, to the starter solenoid. In other words, the starter switch merely closes the relay, which then supplies the initial current surge through a low resistance path.
Whether this is your problem I can't say, but there are numerous threads around on various forums that indicate that this is the fix.
It's on my "to-do" list...
For the last few years I have had an intermittent starting problem. The boat would start every time while at the dock, while hooked into shore power. However, when out on the water for an hour or so, the boat may start or may not. I would then shut down all instruments, fridge, cabin lights or anything else that was ?on?. After a few minutes the boat might start or might not start. I started keeping track of temperature, humidity, length of time off the dock, etc. ? I couldn?t find a pattern. It was very frustrating; a few times I would have to wait 15 minutes before it would start.
I had the same problem this weekend in Raritan Bay, filled to the gills with fishing boats and then the wind died off, the perfect time to start the engine and dodge the always moving fishing boats. When I pushed the start button ? nothing! I had even removed the power for the fans and dash ? figuring I would get more power to the starter solenoid?still nothing. I was done; it had to be fixed ASAP.
I read several dozen articles regarding this problem, some of which suggested grinding down the pins on the starter and starter solenoid. Others, suggested it was due to corrosion on the wires in the starting loop, key switch, momentary on (push button) and the wire leading to the starter solenoid. I found no corrosion and replaced both the key start and push button ? no success, I still had starting problems. There were still more articles blaming the problem on the batteries - new AGM batteries installed and I still have the problem....
The solution: replace the 12 awg wire with a 10 awg wire from the key switch to the push button and replace the second 12 awg from push button to the starter solenoid. It was real easy and once you have all the necessary replacement parts, it takes about 15 minutes to fix.
From the key switch there is a 10 awg wire coming in, on the other terminal there are three wires, a solid red, red with black stripe and white. The red with black stripe and solid red are for powering the fans and dash (alarm, lights and gauges). The white runs to the momentary on with another white 12 awg wire, from the second terminal, running to the starter solenoid. The first step was to fish, using an electricians ?fish tape?, the wire through the console to the aft section of the boat. After fishing the wire thru, the connections were simple, 4 10-12 awg connectors with 8 awg rings.
I left the boat on for about an hour, with everything ?on? (water pumps, anchor lights, all cabin lights, radio?s, hot water heater, autopilot, etc). The boat started three times with ease. The true test will come later this week when I am out for a two hour sail and she either starts or doesn?t on the first try!
GM Starting Problems QED
As I had documented in an earlier post, I had intermittent starting problems, when you hit the push button to start the engine, nothing would happen. The solution was to replace the 12AWG wires from the key switch to the push button and from the push button to the starter solenoid with 10AWG wires.
I had the boat out recently and the problem seems to be resolved. I actually started the boat several times during a recent cruise. It’s really nice to know that you engine is there right when you need it.
Chris - the 8AWG ring connector is a size measurement – you have a 10AWG wire connection with an 8AWG ring connector, if the ring connector is to big you won’t get “full” contact on the keyed and push button wire posts.
The purpose of using solenoids is to get the "juice" (amperage) more directly from the source to the equipment requiring the power, using shorter runs for the actual power and using the branch solenoid wiring to switches or (start) buttons.
For example, as most older Catalinas were made, they had ammeters in the cockpit panel. Since an ammeter is a shunt that measure current flow, it meant that ALL of the amperage had to flow from the batteries all the way back to the cockpit panel and then back to the engine, with resultant voltage drop.
You may have heard about the Engine Wiring Harness "upgrade" that still remains a large issue for older boats, not only Catalinas.
Read this: http://c34.org/bbs/index.php/topic,4546.0.html
and this: http://www.c34.org/wiki/index.php?title=Engine_Harness_Upgrade
What it did was remove the ammeter, replace it with a volt meter, and send the current directly from the batteries to the starter, avoiding the long run back to the cockpit panel.
This is similar. You can either make the wires bigger, or you can install a solenoid, which is essentially a simple momentary relay.
Actually, Hermit, we forgot to ask you if you still have an ammeter in your cockpit panel.
There is also a very good M25 engine (or any others with glow plugs) solenoid project to install one for the glow plugs, which is a similar issue. See: http://www.c34.org/wiki/index.php?title=Faster,_More_Efficient_Glow_Plug_Heating_with_a_Solenoid
This link has a wiring sketch for the "12V challenged" to see how solenoids are wired.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
I have the same engine and have had the same problems. First, the solenoid is near the starter, so the signal wire from the switch should be fine. You should also be able to jump the solenoid with the switch on if you want to work right at the engine
My problem was always in the grounds somewhere. The easiest way I found to locate the bad ground was to try and crank the engine, and then feel the connection/wire. If it's an oxidized connection it will be hot and you will know it quick.
I always started on one battery however and as someone explained that could be your problem. I set up my system in accordance with Ample Power's suggestion of only one starting battery and one large house bank (about 630 AH now, it was originally 750 AH but I downsized sweeper batteries to golf carts). All my charge goes to the house bank and the start battery is charged off the house bank by an isolator elliminator (a combiner is similar).
None the less, look first to your grounds.
Have Fun
Joe S
