Sailboat Race
339
Cal Cal 33-2 cape cod
Mattapoisett 'Spring around the Bay' 2009 race. Sailboat "Shannon" and her crew performed great. We placed 9th out of 10 boats in our class. I bought 9th place ribbons for all of my crew. Good PHRF race for both beginners and serious racers, pursuit style 20nm, with staggered start times, gives plenty room for a good fast start.
Tim R.
May 27, 2004
3,626
Nice work William.
9th is ok but I sure hope the 10th place boat didn't buy ribbons! Those guys are a bunch of losers;)
Also, if someone releases the jib sheet, your whisker pole support is going for a swim!
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Just a suggestion, if you sail your jibe angles you would find that sailing higher angles would have saved you a great deal of time over DDW and probably have moved you well up in the standings.
Tim R.
May 27, 2004
3,626
Good point Alan but not true with all boats and all wind conditions. You need to be able to calculate your VMG to determine this.
For instance, my boat with enough wind can get to hull speed DDW. In lighter wind I can sometimes play the angles because of my deep keel.
Currents can also come into play.
Jan 25, 2007
339
Good observations. Lost a boat hook last race. I forgot the whisker pole, but next time I've got a few ideas. This is my 3rd race so their is plenty of room for improvement. I think we were too conservative following a Wauquiez 38 and a Pearson 34, I thought we could've pointed higher, or made a better line for the mark. I was hoping to past either/both on the downwind leg, it was exciting at one point taking the wind out of one's sail but hit the next mark before we could overtake. One boat had no bottom paint? Is that legal in PHRF-NE?
Oct 14, 2005
2,191
William...
I don't think that bottom paint is a PRHF issue, but holding out a boat hook as a whisker pole will get you protested in a formal rules race for sure.
Tim R.
May 27, 2004
3,626
Yup, rules state it must be attached to the mast.
I made the mistake of calling a guy on this last year. He was doing the boat hook thing because he was too lazy to get out the whisker pole(I did not know he had one). So he drops the boat hook and gets out the whisker pole. He beat us. We still laugh about that one.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Tim, of course the heavier the wind the deeper you can run with improved VMG. From the pictures posted I would say the breeze was very light. There would be no need to hold the boom out and you certainly wouldn't want to use a boat hook (even if it was legal) if the breeze was up.
In this case, a 20 degree course change would probably get you passed at least one boat.
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
We do a fair amount of non-spin racing, and nearly always do better wing-and-wing than we do reaching. Sometimes we will reach once, to a point where we can flip the main to put us on a starboard tack wing-and-wing. I know it sounds counter-intuitive, but wing-and-wing tends to work for us.
And yup, poling the genny with a boat hook is a big no-no.
Pursuits are a fun race format. We've got one up in South Freeport this Saturday. If we could only get a certain red Ericson 35 to come up and play..... :)
Tim R.
May 27, 2004
3,626
I can vouch for Gail's success. I have yet to beat them in a race. Gail, time to buy a new boat;) You have way too much experience in that pretty Pearson of yours.
Tempting but with the weather lately we would love to get out cruising. We were supposed to crew for a boat in the Wood I. race but that looks like a bust. Only 3 boats registered and my friend is thinking of not doing it which frees us up to go cruising.
We will have to see how the weekend weather shapes up. You might see us. We had a great time 2 years ago when we sailed your regatta.
Jan 25, 2007
339
Light winds
Yes, 8-10 knots during most of the race, those conditions would've been ideal for flying a spinnaker. Did not know the rule about poling out jib with boat hook, thanks, the boom didn't need to be pushed out, I was leaning on it to look at our progress. We do the same race in September. I'm looking forward to using a "real" whisker pole, the boat hook looked scary at times. No bottom paint seems a great way to go, one guy keeps his sailboat cradled while not in use, he must've had 20 coats of wax on the bottom, the shine was blinding when he past us.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Keeping the boat out of water while not sailing is called "dry sailing". Most smaller OD's are sailed that way.
If you are thinking about a whisker pole I would strongly suggest a line control pole. This will allow you to sail higher angles and still sail wing on wing.
Extending the pole forward will push the clew out and forward. We have a local racing skipper in his eighties who does this all the time to great success.
Tim R.
May 27, 2004
3,626
Oh William, never post pictures of sail trim during a race;). I can see a few things that would help speed you up a bit if you are interested.
Jan 25, 2007
339
Free advice is my reason for the post...
I'm interested. I welcome, any trick, advice, observation, sail trim, ect to make me sail faster. Remember, I'm at the bottom of the learning curve. Only room to move up.
Tim R.
May 27, 2004
3,626
Just from that photo of you apparently on a reach I would check your job halyard tension as the headsail luff looks pretty loose. You do not want any horizontal lines like you have. Also play with your jib sheet lead blocks. The angle on the jib sheet is such that it is probably spilling wind at the top where there is considerable twist in the sail. Moving the blocks forward will help this. A good place to start is the equalize the angle between the sheet and the foot and leech of the sail. Then move forward or back to tweak the settings. Ideally you want all your telltales to stall at the same time if you were to head into the wind. A slightly different setting may be ideal for your boat but this is a good place to start.
Go out and sail in some consistent wind conditions with your crew and play with these things until you find what makes you go the fastest.
Also, tell your crew to snap out of it. The guy on the cabin looks bored enough to jump ship.;)
Sep 29, 2008
1,940
Catalina 310 #185 Quantico
Let's get more specific about PHRF's
OK, last week I raced in the Geico Cup in Alexandria, VA. Got spanked which I expected, but what is weird is how PHRF ratings are calculated. Theoretically I understand them, but they are also supposed to be based on real race results in your area. The Chesapeake Bay Yacht Racing Association (CBYRA) gives me a 186 and every other boat was well over 200 (with most around 240). Now I understand that due to my 310's length that my theoretical boat speed is higher, but that also requires higher winds that we seldom see on the river or Bay. I did hit 9.3 knots in a race on a beam reach a couple of years ago, but we had a front coming through with winds of 28-32 knots all day sustained. Normally we have 5-6 knots of wind with occasional gusts or more common lulls and no waves or even chop. All of these smaller and lighter boats with huge PHRF's and down right gorgeous kevlar racing sails are spanking my tail off. But, did I mention I had a good time anyway.
Pearson 26W Marblehead
phrf racing
A few years ago I had a pearson 10M and raced it phrf. My rating was 144. I didnt do that bad when It was breezy but in light air the boat wouldnt move. Another racer with a C&C 33
several thousand lbs lighter with a shorter waterline phrf about 147 walked away from me in light air. Beat me scracth easily and I had to give him time. I talked about this with the race committee and they told me ratings are not figured on how much wind there is but on the
actual waterline, beam, sail area, draft ect:
Tim R.
May 27, 2004
3,626
RP, don't expect to do well at your first race. It takes time to master racing and a lot of it is local knowledge of currents and wind shifts.
My rating is 141 and I race against boats that are much smaller and rate 249. I often beat them now but my first couple of years I could not touch them.
If you are in the theoretically fastest boat(scratch boat) you already have a distinct advantage over your competitors by being able to sail in clean air. Faster boats also have the advantage of finishing before the wind dies. This is common for the evening beer can races. If you beat the smaller boats, they would bitch about these factors.
Dec 4, 2008
264
Other people's boats - Milford, CT
PHRF ratings
OK, last week I raced in the Geico Cup in Alexandria, VA. Got spanked which I expected, but what is weird is how PHRF ratings are calculated. Theoretically I understand them, but they are also supposed to be based on real race results in your area. ... All of these smaller and lighter boats with huge PHRF's and down right gorgeous kevlar racing sails are spanking my tail off. But, did I mention I had a good time anyway.
A PHRF rating assumes that you have good sails and a clean bottom. If you have old sails and the competition has "gorgeous kevlar racing sails", you ain't gonna win, no matter how fair the ratings are.
Todd
Jan 25, 2007
339
Race day..
Good observations, the guy on the cabin is a (hungover) drunk. I've got 2 good crew (out of four) one has raced shields class for years and the other is just a solid cruising sailor. The three of us sail, the other two are escaping from their wives. As we sharpen our sailing skills the other two will need more coaching, I'll need to step up & keep them working on the task.
The jib halyard loosened from a wobbly winch on the mast, I didn't notice until the after the race, next time I'll fasten the jib halyard more taunt, looking at the photo I can't believe I didn't notice it.
As far as Kevlar sails, it's not in my budget, my main dacron is relatively new, I'll have to make the best of it. I like the idea of a line controlled whisker pole. Getting the most from my boat and crew is fun. I'm becoming obsessed like Ahab, To the last I grapple with thee...
