Gas additives
62
Grampian 23 Bobcaygeon ON
How do they affect 4 stroke 9.9 engines? My Merc Big-Foot does not start consistantly. VERY frustrating!!! A call to Mercury headquarters, and speaking with a Tech Expert, I was told the ethonal and other gas impurities are the problem for many small 4 strokes. Especially when they may sit for several days between runnings.
Their solution... add Quick Clean to each tank of gas. Any experiences with this problem? Others have said to only use High Test gas. This is a manual-start motor. Would an electric start make any difference? Any comments AND advice will be much appreciated. Roger
Jan 10, 2009
590
PDQ 32 Deale, MD
I have a Yamaha 9.9 and a smaller Merc - similar issues.
Cleaning the carb helps. Small passages get clogged, and the needle can stick.
Enriching the idle mix a little helps, particularly if it is a pre-ethanol motor.
Keep a can of starting fluid on the boat. While it is not for regular use, a tiny tiny squirt can make a difference when needed.
Yet some motors are totally uneffected. I have a 18hp Nissan on another boat, and I can ignor it for months and it will start on the first pull. Don't know.
Oday Mariner Quadra Island BC
It has been my observation that the new 4strokes (I have a Yamaha 8hp) regardless of brand can be cold blooded creatures. Mine starts first or second pull every time but it takes some high idle time to warm up enough so it doesn't stall when put into gear. Kinda reminds me of all the Ford's I ever owned. LOL
Dec 9, 2008
426
1980 Hunter 30 "Denali" Seaford, VA
I lean toward Seafoam as my additive of choice but I only add it if the boat will be sitting for a couple of days or longer. If I think I will go through a fuill tank I don't bother. I am mainly worried about stabilizing the fuel and keeping the carbs clean. This is on my older 115HP 2-stroke outboard on my fishing boat, not a small, new, 4-stroke.
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
A previous boat had a Honda 7.5. I found a shot of carbuertor cleaner run through it helped, and when the float stuck, a tap on the bowl with a screwdriver handle freed it. Many 4-strokes benefit from a bit of Marvel Mystery oil in the fuel.
Oct 5, 2008
62
Thanks All! Seems additives are the order of the day, specially for the newer motors...
Companies should add that caveat--about gas. It would have taken many anxious moments out of my days...
"...keeping carbs clean..." takes more expertice than i have. Though it would be nice to know what/how to do some of the DIY things when in a tight spot.
Such additives--from Merc--are just now available in Canada. My dealer didn't believe me until he phoned, while I was there, and ordered me a can...
What abour Hi-Test Gas? Any experience with use??
Thanks again! A great resource site!! Roger... Lock 32 Trent Canal...Y'all come-by :)
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Try and run the engine out of fuel when leaving the boat for more than a few days. Per my Honda mechanic's suggestion (after a carb rebuild $$) at the end of my weekend I disconnect my fuel line from my tank and let the engine idle until it dies. Actually as I start getting close to the marina I pull the line and dock with the fuel line disconnected. Haven't had a problem since. I occasionally add some carb cleaner in the fuel just in case.
Manny
Dec 9, 2008
426
Manny
I'm not a real engine guy (hence the sailboat perhaps), but there are those that argue against running an engine out of fuel due to the lack of lubricant. This may apply more to 2 strokes though.
RichH
Feb 14, 2005
4,773
Manny
What Manny states should be standard practice on ALL small gasoline engines to keep the carb. clean, and not fouled, etc.
Also be sure to use a fuel stabilizer in the tank .... or better, only use FRESH (less than 30 days old) gasoline.
Oct 5, 2008
62
More "THANKS!" I'll run these suggestions/advice by Merc's Head-office tech experts for their reaction.
At one time I ran the motor dry and was "severely scolded :)" by the dealer, who said to refill the carb required a lot of "pulls" on the manual start???
Ever learning... Roger
larryw
Jun 9, 2004
395
Shouldn't take too many pulls if you have a bulb in the fuel line. Squeeze it till it's firm (don't go there) and the bowl should be full.
Pearson 26W Marblehead
outboard starting problems
Ive got a 2008 4 stroke tohatsu
What the guys say is correct:
I have followed the steps below and never had any trouble. Per the dealer that sold me the motor
1. Dont use gas that is over 30 days old Any 30 day old gas gets poured into my cars gas
tank.
2. Put a capful of starbrite stabelizer in your fuel tank upon refilling
3. Always run the engine out of fuel when finished for the day This will avoid a gummed up
carburetor, especially if the boat is going to sit for several days
4. make sure your bulb is hard before starting.
5. Finally a couple of minutes warm up with the choke is normal before putting the engine in gear
Oct 5, 2008
62
Motor started at dealers with Hi-test & Quikleen in tank... Tomorrow I hope I can get someone to help me get it on da boat... I'll report back with the results.
REALLY appreciate YOUR TIME AND ADVICE!!!
Roger
